I need a help in Assembly language
samara
Joined Jun 5, 2008
Hi every body..
Im samarah
Im new member in this forum
I need your help,coz I can't solve a program in assembly languge
Can you help me??
samara
Joined Jun 5, 2008
thank you All
Im so happy:)
Ok..
I m working with 8086
I want to solve the matrix multiplications
that is A and B and the result will stor at C
it defined as:
Cik = Aij * Bik
A,B and C there size is 4*4
where j is summed over for all possible values of i and k,there for , in order for matrix multiplication to be defined , the dimensions of the matrix must satisfy
(n*m)(m*p)=(n*p)
this is my code but Ithink it not good:(
I want better one
.model small
.data
m equ 4
k equ 2
n equ 4
xmat dw m*k dup(0)
ymat dw k*n dup(0)
buffer db m*n*20 dup(0)
result dw m*n*2 dup (0)
marker db (0)
f_input db "input.dat",0
f_output db "output.dat",0
inhandle dw ?
outhandle dw ?
buffersize dw ?
err_open db "couldn't open file !","$"
err_creat db "couldn't create the file","$"
err_write db "couldn't write the file","$"
err_close db "couldn't write the file","$"
msg db "Press any key to continue...","$"
.code
main: mov ax,@data
mov ds,ax
call open
call read
mov di,offset buffer
mov si,offset xmat
mov cl,m*k
call asciitobin
mov cl,k*n
mov si,offset ymat
call asciitobin
call matrixmul
call bintoascii
call creatfile
call writefile
mov bx,inhandle
call closefile
mov bx,outhandle
call closefile
mov dx,offset buffer
call err_msg
mov dx,offset msg
call err_msg
mov ah,07h
int 21h
mov ah,4ch
int 21h
open proc near
mov ah,3dh
mov al,0
mov dx,offset f_input
int 21h
jc o_error
mov inhandle,ax
jmp o_exit
o_error: mov dx,offset err_open
call err_msg
o_exit: ret
open endp
err_msg proc near
mov ah,9h
int 21h
ret
err_msg endp
read proc near
mov ah,3fh
mov bx,inhandle
mov cx,m*n*20
int 21h
ret
read endp
asciitobin proc near
mov bh,0
mov bp,10d
next: mov ax,0
here: mov bl,[di]
cmp bl,20h
je there
sub bl,30h
mul bp
add ax,bx
inc di
jmp here
there: mov word ptr[si],ax
inc di
add si,2
dec cl
jnz next
add di,2
ret
asciitobin endp
matrixmul proc near
mov si,0
mov di,0
mov cl,m
lp2: mov ch,n
mov bx,0
lp1: call vectormul
mov result[di],ax
mov result[di+2],dx
add di,4
add bx,2
dec ch
jnz lp1
add si,k*2
dec cl
jnz lp2
ret
matrixmul endp
vectormul proc near
push si
push bx
push cx
push bp
push di
mov bp,0
mov di,0
mov cl,k
lp: mov ax,xmat[si]
mul ymat[bx]
add bp,ax
adc di,dx
add si,2
add bx,2*n
dec cl
jnz lp
mov ax,bp
mov dx,di
pop di
pop bp
pop cx
pop bx
pop si
ret
vectormul endp
bintoascii proc near
mov si,offset marker
sub si,4
mov bx,10
mov cl,m*n
mov bp,sp
lp4: mov ax,word ptr[si]
mov dx,word ptr[si+2]
mov ch,0
lp3: div bx
add dx,30h
push dx
inc ch
mov dx,0
or ax,ax
jnz lp3
push cx
sub si,4
dec cl
jnz lp4
; storeing in buffer section
mov bl,m
mov dx,0
lp7: mov bh,n
lp6: pop cx
lp5: pop ax
mov [di],al
inc di
inc dx
dec ch
jnz lp5
mov byte ptr[di],20h
inc di
inc dx
dec bh
jnz lp6
mov byte ptr[di],0dh
mov byte ptr[di+1],0ah
add di,2
add dx,2
dec bl
jnz lp7
mov byte ptr[di],'$'
mov buffersize,dx
mov sp,bp
ret
bintoascii endp
creatfile proc near
mov ah,3ch
mov cx,0
mov dx,offset f_output
int 21h
jc c_error
mov outhandle,ax
jmp c_exit
c_error: mov dx,offset err_creat
call err_msg
c_exit: ret
creatfile endp
writefile proc near
mov ah,40h
mov bx,outhandle
mov cx,buffersize
int 21h
jnc w_exit
mov dx,offset err_write
call err_msg
w_exit: ret
writefile endp
closefile proc near
mov ah,3eh
int 21h
jnc cl_exit
mov dx,offset err_close
call err_msg
cl_exit: ret
closefile endp
end main
hgmjr
Joined Jan 28, 2005
9,027
thank you All
Im so happy:)
Ok..
it defined as:
Cik = Aij * Bik
(n*m)(m*p)=(n*p)
I want better one
Rich (BB code):
.model small
.data
m          equ 4
k          equ 2
n          equ 4
xmat       dw m*k dup(0)
ymat       dw k*n dup(0)
marker     db (0)
inhandle   dw ?
outhandle  dw ?
buffersize dw ?
.code
main: mov ax,@data
      mov ds,ax
      call open
      call read
      mov si,offset xmat
      mov cl,m*k
      call asciitobin
      mov cl,k*n
      mov si,offset ymat
      call asciitobin
      call matrixmul
      call bintoascii
      call creatfile
      call writefile
      mov bx,inhandle
      call closefile
      mov bx,outhandle
      call closefile
      call err_msg
      mov dx,offset msg
      call err_msg
      mov ah,07h
      int 21h
      mov ah,4ch
      int 21h
open     proc near
         mov ah,3dh
         mov al,0
         int 21h
         jc o_error
         mov inhandle,ax
         jmp o_exit
         call err_msg
o_exit:  ret
open     endp
err_msg proc near
        mov ah,9h
        int 21h
        ret
err_msg endp
read   proc near
       mov ah,3fh
       mov bx,inhandle
       mov cx,m*n*20
       int 21h
       ret
read   endp
           mov bh,0
           mov bp,10d
           next: mov ax,0
here:      mov bl,[di]
           cmp bl,20h
           je there
           sub bl,30h
           mul bp
           add ax,bx
           inc di
           jmp here
           inc di
           add si,2
           dec cl
           jnz next
           add di,2
           ret
asciitobin endp
matrixmul  proc near
           mov si,0
           mov di,0
           mov cl,m
lp2:       mov ch,n
           mov bx,0
lp1:       call vectormul
           mov result[di],ax
           mov result[di+2],dx
           add di,4
           add bx,2
           dec ch
           jnz lp1
           add si,k*2
           dec cl
           jnz lp2
           ret
matrixmul  endp
vectormul  proc near
           push si
           push bx
           push cx
           push bp
           push di
           mov bp,0
           mov di,0
           mov cl,k
lp:        mov ax,xmat[si]
           mul ymat[bx]
           add bp,ax
           adc di,dx
           add si,2
           add bx,2*n
           dec cl
           jnz lp
           mov ax,bp
           mov dx,di
           pop di
           pop bp
           pop cx
           pop bx
           pop si
           ret
vectormul  endp
           sub si,4
           mov bx,10
           mov cl,m*n
           mov bp,sp
           mov ch,0
lp3:       div bx
           add dx,30h
           push dx
           inc ch
           mov dx,0
           or ax,ax
           jnz lp3
           push cx
           sub si,4
           dec cl
           jnz lp4
           mov bl,m
           mov dx,0
lp7:       mov bh,n
lp6:       pop cx
lp5:       pop ax
           mov [di],al
           inc di
           inc dx
           dec ch
           jnz lp5
           inc di
           inc dx
           dec bh
           jnz lp6
           add di,2
           add dx,2
           dec bl
           jnz lp7
           mov buffersize,dx
           mov sp,bp
           ret
bintoascii endp
creatfile  proc near
           mov ah,3ch
           mov cx,0
           int 21h
           jc c_error
           mov outhandle,ax
           jmp c_exit
           call err_msg
c_exit:    ret
creatfile  endp
writefile  proc near
           mov ah,40h
           mov bx,outhandle
           mov cx,buffersize
           int 21h
           jnc w_exit
           call err_msg
w_exit:    ret
writefile  endp
closefile  proc near
           mov ah,3eh
           int 21h
           jnc cl_exit
           call err_msg
cl_exit:   ret
closefile  endp
end main
Reformatted using CODE tags to enhance readability.
What is it about your code that needs to be improved?
hgmjr
samara
Joined Jun 5, 2008
hi every body
the code is correct
but my teacher dont like it
I must solve it in another way But Icant chagne my idea
So I need your help
Wendy
Joined Mar 24, 2008
23,797
Two comments,
Make a flow chart of your code, this will allow other people to follow it a lot easier. It also makes writing code like this a LOT easier.
Use comments as has been mentioned. These comments can refer back to the flow chart. Comments are your friend and ally.
I've never written 8086, but I have done some limited coding in Z80, which is pretty similar because the processors are related. I've also written in 6502, which is considerably easier because the op code set is much better organized. Anything in the 808X (which includes the Z80) command set evolved, and wasn't planned from scratch.
In the beginning there was the 4004, and it was good.
Intel declared, LET THERE BE MORE BITS, and the 8008 was born, and it was good.
And the 8008 begat the 8080, and it was good, if slightly kludgy.
And the 8080 split assunder, and thus the Z80 and 8086 was born.
And the 8086 morphed into the 8088, and it was even more kludgy.
And then 8186 was born stillborn, after wiggling for a short while.
And the 8286 was born, and DOS found it good, but everyone else scratched their heads.
And thus the 8386 was born, which devolved into a SX. No one knew why. Windows Loved It.
Which begat the 8486, the last of the absolute standards.
Which begat the 8586, which the Supreme Court found copyrightable, and the tower of Bedlam was brought low.
Mark44
Joined Nov 26, 2007
628
These would be 80186, 80286, 80386, 80486, and 80586, although I'm not sure that Intel used the last number much, and seemed to prefer Pentium instead.
Mark44
Joined Nov 26, 2007
628
hi every body
the code is correct
So I need your help
It might be that your teacher actually likes this code but suspects that you might not have written it. If you wrote this code yourself, you would understand it well enough to be able to change it. If you didn't write it, and therefore are less likely to understand it, it will be difficult for you to change it.
Just playing devil's advocate here...
