All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > General Electronics Chat
Notices
General Electronics Chat Discussion forum for general chat about anything electronics related, including asking questions about material in the All About Circuits E-book, Worksheets, and Videos.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 05-26-2008, 06:09 AM
LukeDXB LukeDXB is offline
Default multiple power sources (DC circuits)
Hi Everyone,
I have a general question.
I can calculate series and parallel circuits ok, with one power source, such as a battery but how do I work out resistance values when there are two power sources (in a DC circuit)?
For example, two 9v batterys wired in series, with 1 X 5 ohm and 1 X 10 ohm resistor and a 12v lamp - all in series.
Regards,
Luke
  #2
Old 05-26-2008, 07:25 AM
nanovate nanovate is offline
Default
add them together
  #3
Old 05-26-2008, 02:59 PM
John Luciani's Avatar
John Luciani John Luciani is offline
Default
Quote:
Originally Posted by LukeDXB View Post
Hi Everyone,
Regards,
Luke
The general method would be to use superposition. You determine the effect due to each
power source individually, by disabling all but one source, and add the effects.
To disable a voltage source replace it with a short circuit. To disable a current source
replace it with an open circuit.
For two equal voltage sources in series disabling one source gives you a current V/R.
Disabling the second source also gives you a current V/R. Adding the two currents
together gives you 2V/R.
(* jcl *)
Tags
Related Site Pages
Section Title
Worksheet Thyristor application circuits
Worksheet AC network analysis
Worksheet Series-parallel combination AC circuits
Worksheet Series and parallel AC circuits
Worksheet Series-parallel DC circuits
Worksheet Series DC circuits
Textbook Parallel batteries : Dc Circuits
Textbook Battery construction : Batteries And Power Systems
Textbook What is network analysis? : Dc Network Analysis
Textbook Simple series circuits : Series And Parallel Circuits
Similar Threads
Thread Thread Starter Forum Replies Last Post
Multiple Source Power Supply Bob O Homework Help 4 02-20-2008 03:10 AM
Power in a AC Series LCR Circuits. asimbhawsinghka General Electronics Chat 2 11-01-2007 07:15 AM
Connecting multiple switched power supplies together MarkF General Electronics Chat 1 01-17-2007 01:34 AM
Re: Constant power supply to multiple application Short Circuit General Electronics Chat 1 11-16-2006 11:37 AM
power in ac circuits wizardb4u Homework Help 1 01-24-2004 06:40 AM
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
