All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > General Electronics Chat
Notices
General Electronics Chat Discussion forum for general chat about anything electronics related, including asking questions about material in the All About Circuits E-book, Worksheets, and Videos.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 05-25-2008, 12:48 AM
Lainya Lainya is offline
Question Frequency sweep for a high-pass filter???
We had a basic resistive-capacitive high-pass filter. In the manual frequency sweep the output voltage across the resistor increased with frequency as it was supposed to until we reached 1MHz, then the voltage dropped. What could cause this? Would the capacitor beaking down cause this? We are working with really old capacitors.
  #2
Old 05-25-2008, 01:05 AM
mik3's Avatar
mik3 mik3 is offline
Default
Quote:
Capacitors are not perfect as well as resistors and wires. Your capacitors may be broken but what i suspect is that after 1 MHz the stray inductance of the capacitors leads and the inductance of your wires (if they are long) cause the voltage to drop because the stray inductance in series with the capacitor form a band-pass filter.
  #3
Old 05-25-2008, 08:14 PM
hgmjr's Avatar
hgmjr hgmjr is offline
Super Moderator
Default
Can you post a schematic of the circuit so that we can study it? It is always easier to discuss a circuit when a schematic of the circuit in question is present.
hgmjr
  #4
Old 05-25-2008, 09:39 PM
SgtWookie's Avatar
SgtWookie SgtWookie is offline
Expert Member
Default
"Ideal" capacitors consist of only capacitance - but they exist only in simulations.
"Real" capacitors, along with capacitance, have relatively small parasitic values of resistance and inductance. The higher the frequency, the more apparent these parasitics become. See the attached.
All electronic components have parasitic values besides their main attribute. Even resistors have parasitic inductance and capacitance.
__________________
General info:
If you have a question, please start a thread/topic. I do not provide gratis assistance via PM nor E-mail, as that would violate the intent of this Board, which is sharing knowledge ... and deprives you of other knowledgeable input.
Tags
Related Site Pages
Section Title
Worksheet Passive filter circuits
Worksheet Resonance
Worksheet Capacitive reactance
Worksheet Inductance
Textbook Resonant filters : Filters
Video Lecture Op Amp Applications - Active Filters - Op Amps and Op Amp Circuits
Textbook High-pass filters : Filters
Textbook Low-pass filters : Filters
Textbook Resonance in series-parallel circuits : Resonance
Textbook Signal coupling : Ac Circuits
Similar Threads
Thread Thread Starter Forum Replies Last Post
how to reduce the cutoff frequency of a high pass filter? PANKAJ DHINGRA The Projects Forum 4 06-27-2013 08:38 PM
Adjustable Single Supply High Pass Filter Robert.Adams General Electronics Chat 2 10-17-2012 12:36 AM
E-book Help Resistor role in a high pass filter boogie General Electronics Chat 11 12-24-2010 09:01 PM
Design signal in Matlab ethan007 Programmer's Corner 2 05-12-2009 02:50 PM
High pass filter - detailed explanation grushka Homework Help 3 02-04-2009 01:35 AM
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
