All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > General Electronics Chat
Notices
General Electronics Chat Discussion forum for general chat about anything electronics related, including asking questions about material in the All About Circuits E-book, Worksheets, and Videos.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 05-23-2008, 01:59 PM
Bill_Marsden's Avatar
Bill_Marsden Bill_Marsden is offline
E-book Developer
Default High Speed Op Amp Query
What is a good cheap modern high speed op amp? It has to have basic DC characteristics, but more than basic stability isn't important DC wise. Cost is important, as is availability. Think a modern 741 (although dual or quad is better).
OK, started the table, which will likely always be a work in progress. This is obviously very preliminary. Keeping in mind we want this fit a standard page, what other specs are needed? Word of mouth on specs will be accepted.
__________________
"Good enough is enemy of the best." An old engineering saying, Author unknown.
General info:
If you have a question, please start a thread/topic. I do not provide gratis assistance via PM nor E-mail, as that would violate the intent of this Board, which is sharing knowledge ... and deprives you of other knowledgeable input. Thanks for the verbage Wookie.
  #2
Old 05-23-2008, 02:13 PM
SgtWookie's Avatar
SgtWookie SgtWookie is offline
Default
Have you looked at LF353's? Wide bandwidth (4 MHz) JFET input dual opamps. Cheap. You won't find it at your local Radio Shack, but DigiKey, Mouser, and many other places stock 'em. From Mouser, you could get 10 of 'em for $3.10 + shipping. Checked over at Jameco, for quantities of 5 or more you can get 'em for around $0.17 each.
__________________
General info:
  #3
Old 05-23-2008, 02:17 PM
thingmaker3's Avatar
thingmaker3 thingmaker3 is offline
Super Moderator
Default
Will this one be fast enough? http://focus.ti.com/lit/ds/symlink/ths4303.pdf
__________________
"I want to establish in your mind very clearly that you must not think I deny all that I do not admit. On the contrary, I think there are many things which may be true, and which I shall receive as such hereafter, though I do not as yet receive them; but that is not because there is any proof to the contrary, but that the proof in the affirmative is not yet sufficient for me"
- Michael Faraday
  #4
Old 05-23-2008, 04:46 PM
Papabravo's Avatar
Papabravo Papabravo is offline
Default
I'm kinda partial to the TL081/TL082/TL084 and its cousins the TL071/TL072/TL074
__________________
We never have time to do it right,
But we always have time to do it over.
  #5
Old 05-23-2008, 05:23 PM
SgtWookie's Avatar
Default
Quote:
The LF353 is similar to the TL072, but the TL072's BW is 3MHz, whereas the LF353 is 4MHz.
If you need more bandwidth, take a look at LT1057's by Linear Technology.
If you need LOTS of bandwidth, check out National's LM6152; a dual opamp with rail/rail inputs & outputs and 75MHz GBW product. They'll set you back about $3.50 each in small quantities.
__________________
General info:
  #6
Old 05-23-2008, 05:29 PM
Audioguru's Avatar
Audioguru Audioguru is offline
Default
The TL071, TL072 and TL074 opamps are the same as the TL08x but are selected for low noise. They have FET inputs so have almost no input bias current and very low current noise. They have a bandwidth of 100kHz at full output.
But they have the problem of older FET-input opamps called "opamp phase inversion".
  #7
Old 05-23-2008, 06:24 PM
Papabravo's Avatar
Default
Absolutely correct.
I have also been burned by a similar problem with an LM324 (PNP inputs), used in a single supply process control application as a unity gain follower, where the input went below the negative rail, and the output went to +Vout(MAX). The quick and dirty fix was a schottky diode clipper on the input.
One problem with the OP is that we lack a precise definition of high speed. Cheap and available we understand.
__________________
  #8
Old 05-23-2008, 06:27 PM
SgtWookie's Avatar
Default
That's just one of the nice things about the LT1057. It's protected against phase reversal.
__________________
General info:
  #9
Old 05-23-2008, 06:52 PM
Papabravo's Avatar
Default
Quote:
OK, but they are not cheap.
From Digi-Key, $4.50 and $8.75 each in QTY. 1 for the available parts and $2.95 for the SOIC with minimum order quantity of 600 where they only have 282 available. What a laugh riot, I guess if you order 600 they'll ship what they have and back order the rest.
Spot check of other prices for DIP parts
Code:
TL082 is $0.44
TL072 is $0.50
LF353 is $0.50
__________________
  #10
Old 05-23-2008, 07:28 PM
SgtWookie's Avatar
Default
I hear you, but look at the other specs.
A 741 op amp is like a '66 Ford Fairlaine straight six with 3-on-the-tree, patched upholstery, rusted floorboards and a burned-out headlight. It might get the job done, but you'll ditch it as soon as you can afford something better.
An LM348 is like a '66 Ford delivery van with bald tires and a busted headlight; bulky and ugly, but just might get the job done.
A TL082 is like a '71 Chevy Chevelle.
A TL072 is like a '71 Pontiac Bonneville (like the Chevelle with the deluxe interior; sound deadening)
An LF353 is like a '72 Olds 442 (quiet like the Bonneville, but faster)
A LM6152 is like a Corvette.
An LT1057 is like a Cadillac Coupe DeVille with a two-tone paint job, chrome wheels, and fuzzy dice hanging from the rear-view mirror.
A THS4303 is like a Formula 1 race car. Not exactly something you'd want to go grocery shopping with, but you'll turn heads in the process.
__________________
General info:
Bookmarks
Tags
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
high speed clock divider shukimann General Electronics Chat 2 05-09-2008 03:00 AM
designing a high speed 8 bit full adder/subtractor in one ckt praveen_gundkal The Projects Forum 1 02-08-2008 02:54 PM
latest high speed technology for core networks angeline_happyoo Homework Help 4 09-24-2007 03:07 PM
NPN to PNP high speed signal conversion diesel General Electronics Chat 8 01-14-2007 07:52 PM
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License. Powered by vBulletin® Version 3.8.5
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
