All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > Homework Help
Notices
Homework Help Stuck on a textbook question or coursework? Cramming for a test and need help understanding something? Post your questions and attempts here and let others help.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 05-22-2008, 03:49 AM
Manmeet Singh Manmeet Singh is offline
Junior Member
Default BJT basics
Im a bit confused about the BJT explanation provided by the site, Ive attached the part that is confusing me
For the first diagram this is pretty bad but since 2 batteries are connected to that node lets say the one on the left is 5V and the right 12V then what would the voltage of the base be? Since both are connected which one sets the voltage of the base lead?
For the second diagram in the reading it said that the base-collector junction is reversed biased therefore it would only be conducting leakage current but then it shows that the forward bias of the base-emitter is allowing a current to flow through this area. How does this make sense?
  #2
Old 05-22-2008, 04:16 AM
Bill_Marsden's Avatar
Bill_Marsden Bill_Marsden is offline
Super Moderator
Default
Bipolar transistors are current devices, the BE junction will forward drop .6 Volts, same as a diode and for similar reasons. This is why you always see resistors in the drawings, to limit the current.
Beta is the parameter name given to define the DC gain a transistor has. It is defined by the Collector to Emitter Current created by the Base to Emitter Current. The Collector to Emitter Current is similar to a variable resistor. B=Ice/Ibe
In both drawings the bias is identical. Care to point the specific paragraph in the book out?
Found it.
http://www.allaboutcircuits.com/vol_3/chpt_2/8.html
You mismatched what was said to the wrong drawing, which has confused the issue quite a bit. What they are talking about is a transistor in the off state, and are trying to explain why it is off. The drawing is showing a transistor that is biased on, where the BE junction has been forward biased, and the collector conducts current.
When the BE junction is reverse biased it will act like a diode, and start dropping voltage in exactly the same way a reverse biased diode will. Look below the discription for the correct drawing.
__________________
"Good enough is enemy of the best." An old engineering saying, Author unknown.
General info:
If you have a question, please start a thread/topic. I do not provide gratis assistance via PM nor E-mail, as that would violate the intent of this Board, which is sharing knowledge ... and deprives you of other knowledgeable input. Thanks for the verbage Wookie.
  #3
Old 05-22-2008, 04:43 PM
Junior Member
Default
"It is customary to reverse bias the base-collector junction of a bipolar junction transistor"...."There is no current flow, except leakage current, in the collector circuit."....."Normally we forward bias the emitter-base junction, overcoming the 0.6 V potential barrier."
This is before the diagrams Ive posted and then below those diagrams it states
"1) forward bias the emitter-base junction, 2) reverse bias the base-collector junction. "
well if this is the case then how would any current be getting through the base collector junction? is there another path the current is taking? the way im seeing it is that the emitter base junction is forward biased but the collector base junction is revsered biased so theres no way you would have any emitter collector current
Tags
Related Site Pages
Section Title
Worksheet Bipolar junction transistors in active mode
Worksheet Bipolar junction transistor theory
Video Lecture Transistor Biasing - Transistors and Transistor Circuits
Textbook Introduction : Junction Field-effect Transistors
Textbook Transistor ratings and packages : Bipolar Junction Transistors
Textbook Current mirrors : Bipolar Junction Transistors
Textbook Meter check of a transistor : Bipolar Junction Transistors
Textbook Introduction : Bipolar Junction Transistors
Textbook Junction field-effect transistors : Solid-state Device Theory
Textbook Bipolar junction transistors : Solid-state Device Theory
Similar Threads
Thread Thread Starter Forum Replies Last Post
Beginner : Basic Bjt inverter ,how bluestone The Projects Forum 4 05-18-2008 10:05 PM
Calculating Base Resistor for a BJT minulescu General Electronics Chat 5 04-23-2008 03:12 AM
Common-emitter ideal BJT Eduard Munteanu General Electronics Chat 6 09-03-2007 08:21 PM
Electronics I Lab (BJT Amplifier) Question PatMcGroin Homework Help 1 06-07-2007 12:09 PM
BJT Test erpay General Electronics Chat 3 03-18-2007 06:59 PM
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2013, vBulletin Solutions, Inc.
