how to make the SCR inverter
thingmaker3
Joined May 16, 2005
5,083
First, you'll need to rectify and filter your 220Vac. Next, use your inverter to create the desired frequency - use this to drive a step-up transformer.
Be extremely careful when working with these very dangerous voltage levels!!! Don't do anything until you are certain of all the hazards and the appropriate safety measures!
banozon
Joined May 19, 2008
Thank's for your reply!
I'll act with caution, but I don't understand how it work in this circuits:
http://www.freeinfosociety.com/electronics/schemview.php?id=1599
Papabravo
Joined Feb 24, 2006
22,111
I would start by assuming that there is an oscillator with an approximate frequency of 400 Hz.
Then I would ask how long it takes for a 12V source to charge the 6.8 uF capacitor through a 1K resistor to the gate voltage of SCR.
When the SCR turns on part of the primary winding is shorted.
AC current will flow around the loop consisting of the 10 uF, primary winding and SCR. As the current returns to 0 the SCR will shut off.
Those hints should get you going.
Wendy
Joined Mar 24, 2008
23,814
Where would the oscillation come from? Once the SCR starts conducting I don't see what would break the current flow, which is required to turn it off.
thingmaker3
Joined May 16, 2005
5,083
Simulation (for what simulation is worth) agrees with the "doesn't work" assessment. At the Free Information Society, you get what you pay for!
Papabravo
Joined Feb 24, 2006
22,111
At least the OP had the good sense to ask about what was confusing him. Considering the reputations of many internet circuit posters I guess we shouldn't be surprised that there is some pretty useless stuff out there.
The better question might be is there such a thing as a working inverter based on an SCR? Could you build a better one with other components?
thingmaker3
Joined May 16, 2005
5,083
The key would seem to be building an oscillator with an SCR. The only such animal I've found on the net (same schematic copied to more than one place) fails for the same reason as the one at the F.I. site.
How might we go about making an SCR oscillate?
Wendy
Joined Mar 24, 2008
23,814
Far as I can tell, you don't. I have seen SCR's used as transistor like switches in pulsating power supplies, but unless you have something to break the current...
MOSFETs work better IMO. I've seen simple invertors using transistors using astable oscillator configurations.
An SCR would work well in a flyback setup I would think, but having never done it I'm not sure.
Caveman
Joined Apr 15, 2008
471
I think it works, but you need the right transformer characteristics. The mutual inductance between the top and bottom halves of the primary is probably most important. The inductance of the bottom side of the primary and the capacitor will resonate so that at one point in the cycle the current through the bottom half will take all of the current from the top half, leaving none for the scr, and turning it off.
