All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > General Electronics Chat
Notices
General Electronics Chat Discussion forum for general chat about anything electronics related, including asking questions about material in the All About Circuits E-book, Worksheets, and Videos.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 05-17-2008, 04:19 AM
relicmarks relicmarks is offline
Default AC voltage meter poor mans oscilloscope
My oscilloscope Analog or digital is way to big for certain jobs to measure under a desk or console
HOw can you use a AC volt meter like a oscilloscope?
How would you know if the sine waveform at 1K hz is going through the input and output of that IC chip?
Use your AC volt meter and measure the INput of the IC chip , it reads a AC voltage, measure the output of the IC chip it reads a AC voltage, Measure the frequency with your DVM on the input and output of the IC CHIP
The DVM meter doesn't give all the instantaneous amplitude values in TIME
So how can you replicate this on a DVM meter?
Since a DVM meter doesn't graph out a sinewaveform how can you mimic it?
Those cheap Handheld Oscilloscpe are around $300 and they are monochrome display , that are really slow
What would you guys do please?
  #2
Old 05-17-2008, 04:30 AM
Externet's Avatar
Externet Externet is offline
Default
Hi.
I have this baby. Some limitations, but works :
http://picotechitaly.8k.com/oszifox1/oszifox.html
__________________
Abolish the deciBel !
  #3
Old 05-17-2008, 05:00 AM
Default
How much was it? it looks cool and small
I wonder why most DVM meters don't have a oscilloscope setting now of days
Any other very small oscilloscope or hand held that are very cheap ?
  #4
Old 05-17-2008, 05:23 AM
SgtWookie's Avatar
SgtWookie SgtWookie is offline
Default
Apparently, they're available at Radio Shack for around $80 according to this website:
http://www.linuxtoys.org/pscope/pscope.html
Much more detailed info there.
__________________
General info:
If you have a question, please start a thread/topic. I do not provide gratis assistance via PM nor E-mail, as that would violate the intent of this Board, which is sharing knowledge ... and deprives you of other knowledgeable input.
  #5
Old 05-17-2008, 05:25 AM
Bill_Marsden's Avatar
Bill_Marsden Bill_Marsden is offline
E-book Developer
Default
Sucker looks expensive, but I hope I'm wrong.
Not too bad. Might get one eventually. Pico is selling a lot of variaty I notice in these kind of instruments.
__________________
"Good enough is enemy of the best." An old engineering saying, Author unknown.
General info:
If you have a question, please start a thread/topic. I do not provide gratis assistance via PM nor E-mail, as that would violate the intent of this Board, which is sharing knowledge ... and deprives you of other knowledgeable input. Thanks for the verbage Wookie.
  #6
Old 05-17-2008, 05:35 AM
Default
They don't sell those radio shack probes anymore i asked
They only have PC interfacing DVM meters
THe DVM meter is set to AC volts, if you measure the AC voltages it stores them for a period , then your download them onto your computer using a software
I tried it out , if you measuring very fast waveforms like vertical or horizontal video syncs the PC interface DVM meter is suppost to store the waveform period and graph it out on the computer but it didn't work that well
Do you guys have a PC interfacing DVM meter , its a DVM meter with a RS-232 cable or USB cable to do the graphing , data logging
What i was thinking if your testing IC chips input and outputs, if i set my DVM to measrure frequency , if i get a 1K hz frequency on the input and 1K hz frequency on the output , wouldn't the IC chip be GOOD because i get the same frequency on the input and output ? i don't have to use a O-scope for this
If i didn't get any frequency at all on the output then the IC chip is bad
or a AC voltagge on the output the IC chip is BAD
THese are ways of testing IC chips or transitor stages without using a O-scope if your just using a DVM meter , its a puesdo 0-scope without a graph waveform
  #7
Old 05-17-2008, 05:39 AM
Default
Yes pico is also , my problem is that i'm working on big consoles and i don't have room for a laptop or the pico interfacing box also it takes up to much room on the console plus it slides down and almost breaks my laptop because the console is at a angle
I need something that is very small
  #8
Old 05-18-2008, 07:32 AM
thingmaker3's Avatar
thingmaker3 thingmaker3 is offline
Super Moderator
Default
Tektronix makes a "THS-700 series." I'm sure their competitors make hand-held battery operated scopes too.
__________________
"I want to establish in your mind very clearly that you must not think I deny all that I do not admit. On the contrary, I think there are many things which may be true, and which I shall receive as such hereafter, though I do not as yet receive them; but that is not because there is any proof to the contrary, but that the proof in the affirmative is not yet sufficient for me"
- Michael Faraday
  #9
Old 05-18-2008, 07:48 AM
studiot's Avatar
studiot studiot is online now
E-book Developer
Default
I've still got the ozifox I had quite a few years ago (notice the Dos/Windows3.1).
It worked OK when new but the build quality must have been poor because it is unreliable now and doesn't always want to fire up.
Also the cable is too short and way too stiff. You need flexible cables for probes.
  #10
Old 05-18-2008, 02:25 PM
E-book Developer
Default
That was a good idea Radio Shack was selling, wonder why it failed? I've been researching it, there is nothing on the market that is comparable.
__________________
General info:
Bookmarks
Tags
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Treatise about Voltage Ratch Physics 100 05-18-2008 07:55 AM
Current and voltage source jasonhaykin General Electronics Chat 9 04-16-2008 07:45 PM
voltage-to-current converter chip for oscilloscope XY mode for curve tracing? relicmarks General Electronics Chat 7 04-07-2008 03:32 PM
voltage dividers pilotnmech Homework Help 16 01-14-2008 02:30 PM
Using my new multi meter and a voltage test meestahelectro The Projects Forum 2 08-14-2006 12:37 AM
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License. Powered by vBulletin® Version 3.8.5
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
