All About Circuits Forum
Go Back   All About Circuits Forum > Abstract Forums > Physics
Notices
Physics Discussion forum for anything physics related.
Closed Thread   Post New Thread
Thread Tools Display Modes
  #1
Old 05-16-2008, 07:18 AM
Ratch Ratch is offline
Banned
Default Ohm's law is not V=IR
As promised, I would like to call your attention to a misnomer in electrical science of the formula V = I*R, which is wrongly called Ohm's law.
First I will show a couple of links.
http://maxwell.byu.edu/~spencerr/web...00000000000000
http://www.launc.tased.edu.au/online...Resistance.htm
Still not convinced? Don't blame you. One can publish anything the WWW.
OK, let's look next at a couple of good physics texts.
I will first quote from a college textbook called Physics, by Halliday & Resnick, 1967, page 780. It was written by David Halliday, Professor of Physics, University of Pittsburgh and Robert Resnick, Professor of Physics, Rensselaer Polytechnic Institute
"We stress the relationship V=I*R is NOT a statement of Ohm's law. A
conductor obeys Ohm's law only if its V vs. I curve is linear, that is, if R
is independent of V and I. The relationship R=V/I remains as the general
definition of the resistance of a conductor whether or not the conductor
obeys Ohm's law. . . . . . . . . Ohm's law is a specific property of
certain materials and is NOT a general law of electromagnetism, for example,
like Gauss's law."
Next a quote from another college textbook called Physics for Scientists & Engineers, by
Raymond Serway, Third Edition, 1990, page 745. It was written by Raymond A. Serway of James Madison University
"A current density J and an electric field E are established in a
conductor when a potential difference is maintained across the conductor.
If the potential difference is constant, the current will also be constant.
Very often, the current density in a conductor is proportional to the
electric field in the conductor. that is J=sigma*E where sigma is called the
conductivity of the conductor. Materials that obey the above equation are
said to follow Ohm's law, named after Georg Simon Ohm (1787-1854). More
specifically,
Ohm's law states that for many materials (including most metals) the
ratio of the current density and electric field is a constant, sigma, which is
independent of the electric field producing the current.
Materials that obey Ohm's law, and hence demonstrate this linear
behavior between E and J, are said to be ohmic. The electrical behavior of
most materials is quite linear for very small changes in the current.
Experimentally, one finds that not all materials have this property.
Materials that do not obey Ohm's law are said to be nonohmic. Ohm's law is
not a fundamental law of nature, but an empirical relationship valid only
for certain materials."
OK, what could be clearer? Ohm's law refers to the linearity between voltage and current, not relationship between voltage, current, and resistance. Yet the formula, V = I*R has been misnamed across countless classrooms, books and discussions. What does your textbook or school teach?
To summarize, certain materials like conductive metals follow Ohm's law, in that their V vs.I curve is linear. Ohm's law is a property of a material, not a general law of nature. Other conductive entities like diode junctions or gas discharge bulbs do not have the Ohm's law property, because their conductivity changes depending on what voltage or current is applied, causing their V vs. I curve to be nonlinear. In all cases, V = I*R is always correct, but it should not be called Ohm's law. It should be called the resistance or impedance formula.
No matter what you call V = I*R, circuits will still get designed and analyzed, and science will still progress.
Ratch
  #2
Old 05-17-2008, 01:31 AM
triggernum5 triggernum5 is offline
Default
Yet in any specific test conditions, Ohm's law must hold for conservational purposes.. ie. a material with a varying resistance, will have a certain resistance under the current conditions..
Analogous to a thermistor in a circuit, except its resistance varies due to temperature, rather than potential..
Ohm's law does hold for non-ohmic materials, but R is a function, not a constant..
  #3
Old 05-17-2008, 01:44 AM
Banned
Default
triggernum5,
The resistance/impedance formula will hold under any voltage and current condition. That formula is not Ohm's law.
Contradictory statement. If a material is non-ohmic, then it does not follow Ohm's law. Ohm's law is a property of a material, not a method of determining resistance from the voltage and current. Ratch
  #4
Old 05-17-2008, 03:41 AM
Default
Well thats a debate over language and semantics.. Those tend to kill quality technical discussion, but I won't disagree with that..
Tags
Related Site Pages
Section Title
Worksheet Calculus for electric circuits
Worksheet Summer and subtractor opamp circuits
Worksheet Class A BJT amplifiers
Worksheet Capacitance
Worksheet Inductance
Worksheet Magnetic units of measurement
Video Lecture Electrical Quantities B - Basic Electronics and Units of Measure
Textbook Specific resistance : Physics Of Conductors And Insulators
Textbook Nonlinear conduction : Ohm's Law
Textbook How voltage, current, and resistance relate : Ohm's Law
Similar Threads
Thread Thread Starter Forum Replies Last Post
Ohms Law, Thevenin and Norton Theory davegulpilil Homework Help 7 03-29-2008 02:20 AM
Ohm's Law hungry4knowledge Homework Help 3 03-27-2008 08:18 AM
Battery Problem KC15 The Projects Forum 5 12-10-2007 03:38 AM
Infor for Ohms Law and Ohms Help! Joey_pr General Electronics Chat 4 11-06-2007 07:59 AM
Ohm's Law: Test tomorrow, HELP! Ubiyca General Electronics Chat 1 09-18-2007 10:54 PM
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
