I need a circuit to provide the following for my wireless router in the loft that siezes up when it has a short power glitch, a power on delay circuit with a battery backup and charge circuit.
I have seen several 555 timer circuits that will power delay the output via a transistor, but my knowledge is way to low to build the battery charging/control parts or integrate the whole thing. As I understand it, the variable input could be controlled by a regulator, but would it need one for the input to control battery charging and one for the input to the 555 timer circuit or more?
Input up to 18 Volts so a wide range of input voltages can be used (6 to 18 or even 24?) I want it to be useful for other people, so a wide range of input would be good.
Output 5 Volts @ 1 Amp, most routers are fairly low power.
The battery is to provide a backup power source when the input power fails, the battery size is variable so I, or anyone else who reads, could use whatever was available, from a small cell to car battery. Ideally the circuit would cut the output when the battery voltage falls to prevent damage to the battery. Also it would prevent the battery from supplying the circuit if it didn't have enough energy and it needs to trickle charge the lead acid cell. I don't mind the cell voltage, please specify.
When the output has failed because of battery exhaustion and/or input power failure, the circuit should delay the switch on of the output by about 30 seconds when the input is restored so that my router doesn't lock up.
Thanks for looking.
Thanks for looking.
