Hello all,
I would like to understand an issue with the Op Amps. The inverting and non-inverting inputs of many of the Op Amp circuits like the summing circuit of the 741 Op Amp are not biased. Is there a crossover disturtion in the out put of the circuit? How can it be corrected if any? If not, how the crossoverdisturtion was eleminated ? when I design a signal amplifier using Op Amp, do I have to consider the biasing and crossover disturtion?
thank you very much for any help.
