All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > General Electronics Chat
Notices
General Electronics Chat Discussion forum for general chat about anything electronics related, including asking questions about material in the All About Circuits E-book, Worksheets, and Videos.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 05-11-2008, 02:34 AM
Bill from Auss Bill from Auss is offline
Post Will Reversed Polarities Kill An Inverter?
G'day mates,
I'm new to this forum, I'm also new to working with inverters.
I bought a 300W inverter off eBay and when it arrived I checked the box and found everything as promised on the sales page. My 12yo grandson who was visiting us asked what I had bought and what was I going to use it for, I told him and he wanted to try it out, I then got tied up on the phone and my grandson went to my shed with the inverter and a 240v tablelamp, he returned to tell me the inverter was not working and when I checked I seen he had reversed the polarieties on the battery...I removed the terminal clamps and placed them back the right way around but the lamp would not light.
The battery was/is fully charged.
The light globe is working as the light is now working in my living room.
Neither the power light or the fault light on the inverter come on when the inverter is attached to a fully chatged battery.
Has my grandson destroyed my inverter by conecting it wrongly to the battery?
I have no wish to tell the suppliers they sent me a faulty inverter and seek a replacement if it's my fault the inverter was dameaged...i.e. I permitted my grandson to make the connection to the battery.
Thanking you for your advice,
Bill from Auss
  #2
Old 05-11-2008, 02:50 AM
beenthere's Avatar
beenthere beenthere is offline
Default
That depends quite a bit on the internal circuit. If there are diodes in the battery supply path, then no harm would have been done. If not, then all the drive circuitry might have been converted to junk.
Take a close look at the printed circuit board. See if any resistors look charred. See if any capacitors look like they have blown their vents or got taller than the label sleeve. See if any discreet transistors have cracks in the epoxy (same for integrated circuits). Quite often, applying reverse voltage to a circuit will cause visible damage - and then ther is always that horrible smell of cooked phenolic...
__________________
First comes the hardware, then the software.
  #3
Old 05-11-2008, 03:05 AM
HarveyH42 HarveyH42 is offline
Default
Maybe a fuse... Would be a very bad design, clip on leads, and no reverse polarity protection. Can you post a brand/model number? Maybe a search on the web will turn something up, least give a better idea what you are working with.
  #4
Old 05-11-2008, 03:20 AM
S_lannan's Avatar
S_lannan S_lannan is offline
Send a message via MSN to S_lannan
Default
I'm 99% sure that any inverter from jaycar will not survive reverse polarity. That includes the whole range.
I've never seen an inverter that can survive reverse polarity. Sure they have fuses, but fuses are not fast enough in a lot of cases.
I've seen some amps with 20A-40A fuses and inside them they had fets literally blown to pieces.
  #5
Old 05-11-2008, 10:47 PM
Audioguru Audioguru is offline
Banned
Default
Many people sell defective junk on E-Bay. Maybe you should.
  #6
Old 06-18-2008, 11:33 AM
Post Thanks but No Thanks!
Quote:
G'day mates and thanks for the answers, as for the quote above...That's not me! I don't need a dollar that badly...been selling on eBay since it first started and still have a 100% rating...my word is my bond!
Anyway, I pulled the unit apart, replaced the fuse and it's working fine now but once again, thanks for your views.
Bill
PS. Anyone know anything about converting a petro car to an electric car?
  #7
Old 06-18-2008, 02:14 PM
thingmaker3's Avatar
thingmaker3 thingmaker3 is offline
Super Moderator
Default
In the interests of good housekeeping, I've pushed the conversion discussion into a new thread: http://forum.allaboutcircuits.com/sh...ad.php?t=12419
__________________
"I want to establish in your mind very clearly that you must not think I deny all that I do not admit. On the contrary, I think there are many things which may be true, and which I shall receive as such hereafter, though I do not as yet receive them; but that is not because there is any proof to the contrary, but that the proof in the affirmative is not yet sufficient for me"
- Michael Faraday
Tags
Related Site Pages
Section Title
Worksheet Electromechanical relay logic
Worksheet TTL logic gates
Worksheet Precise diode circuits
Worksheet Summer and subtractor opamp circuits
Worksheet Inverting and noninverting opamp voltage amplifier circuits
Worksheet Thyristor application circuits
Worksheet Power conversion circuits
Worksheet Bipolar junction transistors as switches
Worksheet Rectifier circuits
Worksheet Rectifying diodes
Similar Threads
Thread Thread Starter Forum Replies Last Post
Having inverter issues Khurram Moon The Projects Forum 7 01-08-2013 01:36 AM
Using an ammeter to monitor a grid tie PV solar inverter? RandySea The Projects Forum 14 09-13-2011 09:39 PM
SMPS Inverter Repair hazim General Electronics Chat 8 03-16-2011 09:11 PM
Signal Inverter RSmith The Projects Forum 5 04-19-2010 02:11 PM
AND Gate + Inverter Question??? HELP lisandro General Electronics Chat 8 07-29-2007 07:22 PM
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
