I have found that I can't display a 8 bit on the lcd, I have tried it for a full day and I can't find any solution, can someone know what error in the code?
thank you very much
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.STD_LOGIC_ARITH.ALL;
use IEEE.STD_LOGIC_UNSIGNED.ALL;
---- Uncomment the following library declaration if instantiating
---- any Xilinx primitives in this code.
--library UNISIM;
--use UNISIM.VComponents.all;
entity LCD is
port( clk:in std_logic;
RST:in std_logic;
Tick : in std_logic; -- Tick at 250 kHz (one clock cycle long)
Din : in std_logic_vector (7 downto 0);
Dav : in std_logic; -- Write Data command (1 clock cycle) if Dav=1 , then write data
Busy : out std_logic;
x : in std_logic_vector (7 downto 0);
y : in std_logic_vector (7 downto 0);
cs : in std_logic; -- choose segment to display
---Lcd signals---------------------------------------
RS
ut std_logic; ---LCD R R_sel
RW
ut std_logic; ---LCD Read/Write
E
ut std_logic; ---Enable
CS1: out std_logic;---LCD chip select 1
CS2: out std_logic;---LCD Chip select 2
Dout: inout std_logic_vector(7 downto 0) --- LCD data
end LCD;
architecture Behavioral of LCD is
-----type defination----
--TYPE State_type IS ( w_Z_SCROLL, w_X_PAGE, W_Y_COL, W_DATA, W_INS,
-- DISPLAY_ON, DISPLaY_OFF, SEGMENT1, SEGMENT2,IDLE) ;
type State_type is (Boot, W_Z_SCROLL,W_Y_COL,W_X_PAGE,Display,Segment_Select,Waiting,WriteData);
-----constant defination----
constant DON : std_logic_vector(7 downto 0) := "00111111"; -- Display on
constant DOFF : std_logic_vector(7 downto 0) := "00111110"; -- Display off
constant Y_ADD : std_logic_vector(7 downto 0) := "01000000"; -- Set Y address 01xxxxxx, xxxxxx is 0-127
constant X_ADD : std_logic_vector(7 downto 0) := "10111000"; -- Set X col 10111xxx, xxx is 0-7
constant Z_ADD : std_logic_vector(7 downto 0) := "11000000"; -- set z address 11xxxxxx, xxxxxx is 0-127
constant write : std_logic_vector(7 downto 0) := "00000000"; -- xxxxxxxx is the data want to write
constant Big_delay : integer := 25000; -- 25000/250 = 100 ms
constant Clr_delay : integer := 5000; -- 500/250= 2 ms
constant Small_delay : integer := 120; -- > 39 us after E down
constant En_delay : integer := 20;
--constant LastPosition : integer := 16;
-----signal defination------
SIGNAL State : State_type;
--SIGNAL Next_State : State_type;
--SIGNAL Count : integer range 0 to Big_delay;
--SIGNAL Count2 : std_logic_vector(7 downto 0);
SIGNAL Z_SCROLL : std_logic_vector(7 downto 0);
SIGNAL X_PAGE : std_logic_vector(7 downto 0);
SIGNAL Y_COL : std_logic_vector(7 downto 0);
SIGNAL DAT : std_logic_vector(7 downto 0);
SIGNAL temp,temp2,INS : std_logic_vector(7 downto 0);
SIGNAL active : std_logic;
signal DavM : std_logic;
signal DataM : std_logic_vector (7 downto 0);
signal Position : integer range 0 to 32;
signal Count : integer range 0 to Big_delay;
begin
--RW <= '0';-------- write mode
process(clk,RST)
begin
if Rst = '1' then
State <= Boot;
Position <= 0;
Count <= 0;
DavM <= '0';
--Lcd_En <= '0';
--Lcd_Sel <= '1';
Busy <= '1';
RS <= '1';
RW <= '0';
E <= '0';
CS1 <= '0';
CS2 <= '0';
Dout <= (others=>'0');
elsif rising_edge(Clk) then
if Dav = '1' then
DavM <= '1';
DataM <= Din;
Busy <= '1';
end if;
if Tick = '1' then
case State is
when Boot => -- Power up wait 30 ms
RS <= '1';
E <= '0';
Busy <= '1';
if Count = Big_delay then
RS <= '0';
Count <= 0;
State <= W_Z_SCROLL;
else
Count <= Count + 1;
end if;
when W_Z_SCROLL => -- Set Function & Mode
Dout <= Z_ADD;
RS <= '0';
if Count = 1 then
E <= '1';
elsif Count = En_delay then
E <= '0';
end if;
if Count = Small_delay then
State <= W_Y_COL;
Count <= 0;
else
Count <= Count+1;
end if;
when W_Y_COL => -- set Entry Mode,
temp <= Y_ADD or y;
Dout <= temp;
RS <= '0';
if Count = 1 then
E <= '1';
E <= '0';
end if;
State <= W_X_PAGE;
Count <= 0;
else
Count <= Count+1;
end if;
when W_X_PAGE => -- set Entry Mode,
temp2 <= X_ADD or x;
Dout <= temp2;
RS <= '0';
if Count = 1 then
E <= '1';
E <= '0';
end if;
State <= Display;
Count <= 0;
else
Count <= Count+1;
end if;
when Display => -- set Display ON
Dout <= DON;
RS <= '0';
if Count = 1 then
E <= '1';
E <= '0';
end if;
State <= Segment_Select;
Count <= 0;
else
Count <= Count+1;
end if;
when Segment_Select => -- set Display ON
if cs ='0' then ---- cs1 enable
RS <='0';
RW <='1';
CS1 <='1';
CS2 <='0';
Dout <= "00000000";
if Count = 1 then
E <= '1';
E <= '0';
end if;
State <= Waiting;
Count <= 0;
else
Count <= Count+1;
end if;
elsif cs ='1' then -----cs2 enalbe
RS <='0';
RW <='1';
CS1 <='0';
CS2 <='1';
Dout <= "00000000";
if Count = 1 then
E <= '1';
E <= '0';
end if;
State <= Waiting;
Count <= 0;
else
Count <= Count+1;
end if;
end if;
when Waiting => -- Waits for input
if DavM = '1' then
DavM <= '0';
State <= WriteData;
RS <= '1';
else
Busy <= '0';
end if;
when WriteData =>
RS <= '1';
RW <= '0';
Dout <= Din;
if Count = 1 then
E <= '1';
E <= '0';
end if;
Count <= 0;
State <= WriteData;
else
Count <= Count + 1;
end if;
end case;
end if;
end if;
end process;
end Behavioral;
thank you very much
library IEEE;
--library UNISIM;
entity LCD is
RST:in std_logic;
RS
RW
E
end LCD;
begin
process(clk,RST)
begin
if Rst = '1' then
State <= Boot;
Position <= 0;
Count <= 0;
DavM <= '0';
--Lcd_En <= '0';
--Lcd_Sel <= '1';
Busy <= '1';
RS <= '1';
RW <= '0';
E <= '0';
CS1 <= '0';
CS2 <= '0';
if Dav = '1' then
DavM <= '1';
DataM <= Din;
Busy <= '1';
end if;
if Tick = '1' then
case State is
RS <= '1';
E <= '0';
Busy <= '1';
RS <= '0';
Count <= 0;
else
Count <= Count + 1;
end if;
Dout <= Z_ADD;
RS <= '0';
if Count = 1 then
E <= '1';
E <= '0';
end if;
State <= W_Y_COL;
Count <= 0;
else
Count <= Count+1;
end if;
temp <= Y_ADD or y;
Dout <= temp;
RS <= '0';
if Count = 1 then
E <= '1';
E <= '0';
end if;
State <= W_X_PAGE;
Count <= 0;
else
Count <= Count+1;
end if;
Dout <= temp2;
RS <= '0';
if Count = 1 then
E <= '1';
E <= '0';
end if;
State <= Display;
Count <= 0;
else
Count <= Count+1;
end if;
Dout <= DON;
RS <= '0';
if Count = 1 then
E <= '1';
E <= '0';
end if;
Count <= 0;
else
Count <= Count+1;
end if;
RS <='0';
RW <='1';
CS1 <='1';
CS2 <='0';
Dout <= "00000000";
if Count = 1 then
E <= '1';
E <= '0';
end if;
State <= Waiting;
Count <= 0;
else
Count <= Count+1;
end if;
RS <='0';
RW <='1';
CS1 <='0';
CS2 <='1';
Dout <= "00000000";
if Count = 1 then
E <= '1';
E <= '0';
end if;
State <= Waiting;
Count <= 0;
else
Count <= Count+1;
end if;
end if;
if DavM = '1' then
DavM <= '0';
State <= WriteData;
RS <= '1';
else
Busy <= '0';
end if;
when WriteData =>
RS <= '1';
RW <= '0';
Dout <= Din;
if Count = 1 then
E <= '1';
E <= '0';
end if;
Count <= 0;
State <= WriteData;
else
Count <= Count + 1;
end if;
end case;
end if;
end if;
end process;
end Behavioral;
