Another power supply question. I'm building onto an existing 240vac machine. I'm getting 120vac from one of the hot legs of the three leads (it uses a three pronged plug) and the ground lead. That gives me a hot and a ground. One of the power supplies I'm using utilizes a three prong plug. I put one hot leg 120 on one prong, the ground/neutral on the other. What do I attach the power supplys dedicated ground lead to?
I imagine the ground from the three prong plug should be connected to the chassis ground of my project. Any other ground points of components will be likewise attached to chassis ground. So if the ground/neutral coming in from the 240 lines is going to be used for neutral whereever 120v needs it does it likewise get connected to chassis ground or left as a 'floating' neutral? Grounding (obviously) has always been a source of some confusion for me.
I was told by a friend (a working electrician) that I can attach the 120v and ground from the 240v service to either of the leads on the power supply and then connect the neutral one to the chassis. In this case I'm simply bridging the dedicated ground on the power supply with the neutral coming in from the power source. Since I'm looking at AC it shouldn't matter he says. I really don't get it. There is no continuity right now (naturally) between either of the power prongs and the ground prong on the power supply. Why bridge them at all? But if not, then how do I ground the chassis of my project? Inside the 240vac machine (a welder) the ground/green wire coming in from the service outlet is attached directly to chassis. I hope this isn't too unclear. Sorry for that.
The reason for using borrowing off of the 240 inside the welder is because I need this 'project' to use the main power switch on the welder. It's only a couple of amps draw so it's no problem with the switch or breakers. It needs to power up/down along with the welder.
