All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > Homework Help
Notices
Homework Help Stuck on a textbook question or coursework? Cramming for a test and need help understanding something? Post your questions and attempts here and let others help.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 05-07-2008, 10:47 PM
tadpole tadpole is offline
Default Current Source vs. Current Sink
Consider an open-collector output connected to a totem-pole input. Do I understand correctly that the open-collector output is a current sink whether its logic value is HI or LO?
  #2
Old 05-08-2008, 12:07 AM
Audioguru Audioguru is offline
Banned
Default
An open collector output can sink a current to 0V but it cannot source a current. It needs to have a pullup resistor or transistor added for its output to source a current and be high.
  #3
Old 05-08-2008, 12:43 AM
Default
Quote:
So if a pull-up resistor of appropriate value is properly connected between the output and the supply voltage, the output logic is HI, and the output is driving a TTL input, is the output said to be sourcing current to the TTL input?
I understand how the connections are made (and how to calculate an appropriate value for the pull-up resistor), but the definition of "source" and "sink" are somewhat unclear to me. I thought a gate output was called a source if the electron flow was going into it, and a sink if the electron flow was coming out of it. I understand that for a properly connected open-collector output, the electron flow comes out of the output whether the output logic is HI or LO (although the current is very small if the output is HI).
  #4
Old 05-08-2008, 12:48 AM
mik3's Avatar
mik3 mik3 is offline
Default
If we say an output source current it means the current flows out of the chip. If way say the output sinks it means the current flows in the chip. By the way you dont need to have a pullup resistor to drive a TTL input because a floating TTL input is taken as high.
  #5
Old 05-08-2008, 01:29 AM
Banned
Default
Most circuits use a positive power supply. If an output goes high (positive) then it sources.
If an output goes low then it sinks.
It is best to drive a TTL input high. TTL outputs force the next input high and do not allow inputs to float. Floating inputs go high very slowly. Floating inputs pickup interference.
  #6
Old 05-08-2008, 01:32 AM
thingmaker3's Avatar
thingmaker3 thingmaker3 is offline
Super Moderator
Default
Quote:
That would be conventional current. Not "electron flow."
__________________
"I want to establish in your mind very clearly that you must not think I deny all that I do not admit. On the contrary, I think there are many things which may be true, and which I shall receive as such hereafter, though I do not as yet receive them; but that is not because there is any proof to the contrary, but that the proof in the affirmative is not yet sufficient for me"
- Michael Faraday
  #7
Old 04-27-2009, 01:05 AM
Vincenzo1309 Vincenzo1309 is offline
Member
Default
Hi
I think it is important to know about the source current, as we can determine how much current actually flows out of the chip. So we can determine how to amplify the current to drive our load, like using a transistor etc.
But why do we have to know what current actually flows into the chip (sink current)? Can it help us in any way?
Kindly advise.
Regards,
  #8
Old 04-27-2009, 03:20 AM
Ron H's Avatar
Ron H Ron H is offline
E-book Developer
Default
Does this help?
On first inspection, it may look like the emitter of Q1 is reversed biased when the input is high, so no current should flow. It is reverse biased, but the collector of Q1 is lower in voltage than the emitter, so their roles are temporarily reversed (inverted). The inverted transistor will have low beta, but current will still flow through the emitter (now the collector) junction.
When the emitter of Q1 is low, Q1 acts as a normal transistor.
EDIT: See the Wikipedia article on transistor-transistor logic if you want to see a typical TTL gate schematic.
  #9
Old 04-27-2009, 03:24 AM
Member
Default
Hi Ron H,
Thanks a lot! It sure helps!
Have a nice day!
Regards,
  #10
Old 05-08-2009, 03:33 AM
Bernard's Avatar
Bernard Bernard is online now
Default
Just take source and sink with a grain of salt[ what ever that means ] ,because IC data sheets do not all agree with each other on the subject; maybe check date of publication.To me an open collector sinks.
Tags
Related Site Pages
Section Title
Worksheet Basic logic gate troubleshooting
Worksheet TTL logic gates
Textbook Current mirrors : Bipolar Junction Transistors
Textbook The common-collector amplifier : Bipolar Junction Transistors
Textbook The common-emitter amplifier : Bipolar Junction Transistors
Textbook Logic signal voltage levels : Logic Gates
Textbook CMOS gate circuitry : Logic Gates
Textbook TTL NAND and AND gates : Logic Gates
Textbook The "buffer" gate : Logic Gates
Textbook The NOT gate : Logic Gates
Similar Threads
Thread Thread Starter Forum Replies Last Post
sink and source currents of series 74LS TTL cruizerdog92 Homework Help 35 07-01-2013 10:17 AM
parallel resistance Rs of a current source PG1995 General Electronics Chat 10 10-02-2011 03:53 PM
parallel resistance Rs in current source PG1995 General Electronics Chat 11 06-05-2011 03:03 PM
Current and voltage source jasonhaykin General Electronics Chat 9 04-16-2008 07:45 PM
About Thevenin Theorem BrillianceLin Homework Help 3 12-04-2007 05:42 PM
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
