All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > The Projects Forum
Notices
The Projects Forum Working on an electronics project and would like some suggestions, help or critiques? If you would like to comment or assist others with their projects, this is the place to do it.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 05-04-2008, 06:43 PM
Neptune769 Neptune769 is offline
Default 24vac to 12vdc
Hello Everyone,
I have a project similar to ScarEye. However I don't know what I would change and to what value. Here is what I have.
I have a 24vac security camera power supply. It puts out 14 amps total with a max. output of 3.5 amps on each of the 16 outputs. I need two circuits. One that will go from 24vac to 12vdc 1 amp min. & one that will go from 24vac to 15vdc 1 amp min.
I can follow a schematic and make a board but I don't know how to figure the values and what I would need.
I am building some IR LED arrays for my CCTV cameras for night vision.
the first is a 104 LED array 8x13 the other has 150 10x15. lots of soldering.
Thanks in advance for any help.
Regards,
Dennis
Tags
Related Site Pages
Section Title
Textbook Special-purpose diodes : Diodes And Rectifiers
Similar Threads
Thread Thread Starter Forum Replies Last Post
AC To DC Converter ScarEye The Projects Forum 42 05-10-2009 11:42 PM
7805 & 12VDC Power Supply Problem JDC The Projects Forum 10 10-24-2008 06:09 AM
12VDC with LED switching problem. dodbdts The Projects Forum 2 07-20-2007 10:51 PM
PWM 12Vdc to 120Vac inverter menotu3169 Homework Help 2 03-09-2007 10:16 PM
12vdc double breaker fsan0566 General Electronics Chat 2 09-14-2006 06:13 PM
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
