All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > Homework Help
Notices
Homework Help Stuck on a textbook question or coursework? Cramming for a test and need help understanding something? Post your questions and attempts here and let others help.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 04-22-2008, 07:46 PM
Jaywin Jaywin is offline
Default Pspice graph with DB() function and without DB()
When put the DB() function the x-axis become log-scale is it?
And for the red circled region is it caused by the delay of capacitor?
Wondering why the voltage raise in the red-circled region...
And for the voltage gain for 2nd order low pass, why after certain frequency the gain raise again for the below graph(Left)?
Why the graph is different if we not using DB() function?
upper is using DB() lower is without using DB().
Thanks, if anyone could to explain to me...thz vry much.
  #2
Old 04-22-2008, 07:51 PM
Caveman Caveman is offline
Default
The voltage is raised in the red region because that is what the circuit does. Look really close at the dB graph and you will see that it is just slightly over 0dB in the same area. That is because 1.1V is 0.87dB.
All dB scale is doing is converting the output to dB.
log_out = 20*log(linear_in)
Does that make sense?
  #3
Old 04-22-2008, 08:04 PM
Default
The circuit is like this same as the previous circuit but just the voltage pointer shifted to the V(R1) node.
Ya, i got what u mean for the dB. Meaning putting dB the axis is change to the log-scale isn it? And observe that the dB graph for the Voltage gain is not started from 0db is this correct?
  #4
Old 04-22-2008, 09:08 PM
Default
Yes, you have a dc gain of 1.58V/V which is approximately equal to 4dB. If you were to remove the 6k resistor and short the 3.5k resistor, you would have 0dB at dc.
  #5
Old 04-23-2008, 05:16 AM
Default
Anyone able to explain for the voltage gain of 2nd order low pass, why the frequency increase until certain value the gain raise again for the below graph(Left)?
Tags
Related Site Pages
Section Title
Worksheet Decibel measurements
Video Lecture Decibels - Amplifier Basics - Transistors and Transistor Circuits
Textbook Decibels : Amplifiers And Active Devices
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
