| General Electronics Chat Discussion forum for general chat about anything electronics related, including asking questions about material in the All About Circuits E-book, Worksheets, and Videos. |
Thread Tools | Display Modes |
#1
Hi all,
I have a circuit that use an IC CD4520 (Binary up counter) to generate 7 steps as the diagram in the link (CD4520 can generate till 15 steps connecting other two resistors on pin 6 and connecting the operational input to the joint of these resistors). http://www.grix.it/UserFiles/odoardo...e%20CD4520.jpg I need that the circuit generate only one step or two steps or three till 10 steps selecting them with a switch. Someone can help me to a right modification of the circuit. Thanks Odo |
#2
Quote:
#3
Thank very much,
so the circuit become this: http://www.grix.it/UserFiles/odoardo...20CD4520_m.jpg I'll test tomorrow. |
#4
Quote:
#5
It's not recommended to run an opamp in open-loop mode continuously, as the output will be in saturation. Texas Instruments specifically recommends against this.
If you want to run open loop, then use a comparator - that's what they're designed for.
__________________
General info: If you have a question, please start a thread/topic. I do not provide gratis assistance via PM nor E-mail, as that would violate the intent of this Board, which is sharing knowledge ... and deprives you of other knowledgeable input. |
#6
I used opamp because in the circuit there is just one not used.
Really the 1M don't need, removeded. Now the circuit works fine from one to 15 steps, by the resistor of 39K connected in series of the pot and +15V reduce to 10 steps max of course connecting the other two resistors to pin6 of CD4520). Just to complete the information this circuit is used on a curve tracer. Thank to all for the best suggestions Odoardo |
#7
But i think that the 1M resistor helps the op-amp to go into deep saturation because it is placed from the output to the non-inverting input (positive feedback).
| Tags |
| cd4520, generator, step |
Related Site Pages
| Section | Title | |||
| Worksheet | Counters | |||
| Worksheet | Performance-based assessments for analog integrated circuit competencies | |||
| Worksheet | Nonlinear opamp circuits | |||
| Worksheet | Precise diode circuits | |||
| Worksheet | Linear computational circuitry | |||
| Worksheet | Summer and subtractor opamp circuits | |||
| Worksheet | Inverting and noninverting opamp voltage amplifier circuits | |||
| Worksheet | Positive feedback opamp circuits | |||
| Worksheet | Negative feedback opamp circuits | |||
| Worksheet | Open-loop opamp circuits | |||
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Bicycle Power Generator | alliag | The Projects Forum | 21 | 06-10-2008 04:28 AM |
| Step Up & Step Down DC CHOpper | Wassouflover | The Projects Forum | 4 | 04-03-2008 01:48 PM |
| Ammeter for standby generator | jwnetsource | The Projects Forum | 5 | 12-11-2007 01:07 AM |
| transformer response to a step input | AlexK | General Electronics Chat | 2 | 06-04-2007 07:58 PM |
| RF Generator Questions_Neophyte | bob_nj | The Projects Forum | 2 | 03-20-2007 12:46 PM |
| Thread Tools | |
| Display Modes | |
