| General Electronics Chat Discussion forum for general chat about anything electronics related, including asking questions about material in the All About Circuits E-book, Worksheets, and Videos. |
Thread Tools | Display Modes |
#1
I need to create a delay of 1 minute using a 555 Timer. The Timer will receive an input from a relay contact (this is not a constant supply), then wait for 1 minute before giving a one shot output. Is this an easy circuit to build? I have come across plenty of timer circuits that will give an output FOR a set time, I need the circuit to WAIT for 1 minute then give the output. Many thanks for any help. |
#3
The one shot is just a positve feed to a PLC, the timer only has to give an output for approx 1 sec.
#4
You will need two 555's (or a 556). The first will go active for 1 minute from the relay contact, and will trigger the second when it times out.
__________________
First comes the hardware, then the software. |
#5
Thanks, Im a bit of a novice when it comes to 555 timers. I have heard of a 556 though. Would you mind explaining a little more about the reason for needing two 555's - when you say the first will go active for 1 minute, then trigger the second.
Thanks a lot. |
#6
When a device is triggered, the output state changes. So a single 555 won't do for your needs. The idea of using two of them is that the first one can trigger the second one. The first gives the 1 minute delay and the second gives the 1 second output pulse.
I'm pretty sure that an LM556 is a dual 555. At any rate, get the data sheet for both. I'm off to bed, try to be more useful tomorrow.
__________________
First comes the hardware, then the software. Last edited by beenthere; 04-20-2008 at 02:19 AM. |
#7
So are you saying that the first will give an output FOR 1 minute, and the second wont do anything until the output from the first 555 goes low.
So the first 555 will immediatley give an output once the relay contact goes high (for 1 minute), and the second will give an output for 1 sec AFTER 1 minute has passed? Sorry for being a bit of a thicko here but your really helping me out. Many thanks again. |
#8
See "Two Stage Time Delay Circuit" :
http://home.cogeco.ca/~rpaisley4/LM555.html#20 Lots of other good 555 stuff here too. ![]() Ken |
#9
If you want you can you use one 555 and a transistor to invert its output. But why dont you use the PLC itself to make the 1 minute delay?
#10
See the attached schematic. Times are approximate, of course - your mileage may vary. You can use two 555 ICs, or a single 556.
__________________
General info: If you have a question, please start a thread/topic. I do not provide gratis assistance via PM nor E-mail, as that would violate the intent of this Board, which is sharing knowledge ... and deprives you of other knowledgeable input. Last edited by SgtWookie; 04-20-2008 at 04:40 PM. |
| Tags |
| 555, delay, minute, time, timer |
Related Site Pages
| Section | Title | |||
| Worksheet | Time-delay electromechanical relays | |||
| Worksheet | Flip-flop circuits | |||
| Worksheet | Timer circuits | |||
| Textbook | 555 MONOSTABLE MULTIVIBRATOR : 555 Timer Circuits | |||
| Textbook | 555 Schmitt Trigger : 555 Timer Circuits | |||
| Textbook | The 555 IC : 555 Timer Circuits | |||
| Textbook | 3-bit binary counter : Digital Integrated Circuits | |||
| Textbook | LED sequencer : Digital Integrated Circuits | |||
| Textbook | 555 audio oscillator : Analog Integrated Circuits | |||
| Textbook | Time-delay relays : Electromechanical Relays | |||
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| intergrator waveform measurements and symmetry | relicmarks | General Electronics Chat | 10 | 04-19-2008 10:45 PM |
| Time Lapse Camera 555 Timer Circuit Question | la quokka | The Projects Forum | 8 | 03-22-2008 02:30 AM |
| Help using 556 in dual time delay | vandyo | The Projects Forum | 0 | 02-25-2008 06:29 PM |
| Simple 555 timer delay on circuit needed | eatumup | General Electronics Chat | 3 | 02-21-2008 04:21 AM |
| quick 555 timer question | skinner927 | General Electronics Chat | 10 | 01-24-2008 05:23 AM |
| Thread Tools | |
| Display Modes | |
