All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > General Electronics Chat
Notices
General Electronics Chat Discussion forum for general chat about anything electronics related, including asking questions about material in the All About Circuits E-book, Worksheets, and Videos.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 04-19-2008, 02:29 AM
HellTriX's Avatar
HellTriX HellTriX is offline
Member
Send a message via ICQ to HellTriX Send a message via AIM to HellTriX Send a message via Yahoo to HellTriX Send a message via Skype™ to HellTriX
Default PWM motor controllers, Half bridge, no bridge, etc
So I have been experimenting with PWM and motor controllers and I now have some questions.
I understand an H-bridge is good for reversing an electric motor. But what is the main purpose of an half bridge? Is it to get forward motor voltage and freewheeling?
I ordered a driver chip but the wrong one came so I was unable to test out a half bridge using 2 N channel fets. So I hooked up a large DC fan from Vcc to the Drain of the mosfet and was able to get a variable motor controller up to about 23amps at 16v (I didn't run it and harder as my fuse is 25Amp).
I only had a single 3A diode in parallel with the motor to help protect the mosfet. I am assuming this is required for power mosfets?
So my next question is. What is wrong with just using a low side mosfet for running this motor? Do I need a high side to provide freewheeling, braking, or is that for protecting the low side mosfet?
The mosfets are 75v 75amp continuous rated and I have a few I'd like to parallel to test a 200 amp motor at 36-48v but I want to understand whats going on better so I don't destroy expensive mosfets.
  #2
Old 04-19-2008, 03:16 AM
SgtWookie's Avatar
SgtWookie SgtWookie is offline
Expert Member
Default
Well, if it's just a single half-bridge, one big advantage is the ability to physically place it away from the other half-bridge so that you can use physically larger heat sinks.
If it's a full H-bridge IC, the power rating will be much smaller than a half bridge; there just is not sufficient area available to dissipate the heat.
__________________
General info:
If you have a question, please start a thread/topic. I do not provide gratis assistance via PM nor E-mail, as that would violate the intent of this Board, which is sharing knowledge ... and deprives you of other knowledgeable input.
Tags
Related Site Pages
Section Title
Worksheet Digital-to-Analog conversion
Worksheet Timer circuits
Worksheet CMOS logic gates
Worksheet Opamp oscillator circuits
Worksheet Insulated gate field-effect transistors
Worksheet Rectifier circuits
Worksheet AC motor control circuits
Textbook Pulse Width Modulation : Dc Motor Drives
Textbook The Silicon-Controlled Rectifier (SCR) : Thyristors
Textbook Rectifier circuits : Diodes And Rectifiers
Similar Threads
Thread Thread Starter Forum Replies Last Post
Help for Half Bridge Driver yasinji General Electronics Chat 2 01-03-2014 08:04 AM
Help Variable PWM using A/D PIC18F2431 trr85 Embedded Systems and Microcontrollers 5 06-12-2009 04:36 AM
Inverter Half bridge $ Bridge??? Adz Homework Help 1 08-28-2008 02:20 AM
Half bridge inverter Marie The Projects Forum 2 05-15-2008 06:15 PM
How can I float the low side gate of a half bridge? arvin Homework Help 9 02-02-2007 06:18 PM
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
