All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > The Projects Forum
Notices
The Projects Forum Working on an electronics project and would like some suggestions, help or critiques? If you would like to comment or assist others with their projects, this is the place to do it.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 04-18-2008, 02:48 PM
Rolandchok Rolandchok is offline
Junior Member
Default 220V AC motor Controller using PWM
hello gyus i want to design an AC motor controller using PWM with an 220V input at 60hz. do you have any circuit relating to this problem? the flow chart as far as i study goes like this from the AC source 220V goes down to a converter that will convert AC to DC signal down to the PWM circuit then PWM Ckt is connected to an inverter that will invert DC to AC signal then an AC motor 220V input will be connected. i have already consulted someone about this and it is possible. i'm also planing to put an error correction on this to so that the Voltage reading really matches the RPM of the motor. can anyone help me with this? its for my project design in our class. thanks guys.
  #2
Old 04-18-2008, 02:53 PM
beenthere's Avatar
beenthere beenthere is offline
Default
This is interesting to hear. I had always thought that AC motor control was done with a VFD circuit. I had always thought that if you ran an AC motor at a fixed frequency, the motor also ran at a fixed RPM.
So this is quite interesting. Can you send details of this PWM controlled inverter? I am sure we would all like to see it. We would need the schematic at least to figure a voltage to RPM indicator.
__________________
First comes the hardware, then the software.
  #3
Old 04-18-2008, 03:09 PM
Junior Member
Default
hmmmm... i still have 7 months to develop this project. after 7 months we will have an exhibit and i'm planning to present this one. i'm still figuring out how to develop the PWM of this circuit any suggestion. for sure the error correction will be attach on the AC mottor. there is a generator attach on in the voltage generated on the generator is being Feedback to the PWM circuit to see if circuit will adjust the freq. hmmm... as i have research at 60hrz the motor runs at 0-100% at 120hrz it could run from 0-200% so the significance of this study is extracting more juice on an AC motor. even let say about 150%. can you help me with this one?
  #4
Old 04-18-2008, 03:15 PM
Junior Member
Default
inverter Ckt are easy to develop from DC to AC my main prob is in the PWM Ckt that will regulate the AC motor. feedback circuit will be at the end part. and another attachment to it is controlling the motor wireless. very nice design.
  #5
Old 04-18-2008, 04:00 PM
beenthere's Avatar
Default
Inverters are designed to make AC from DC. Without the schematic of the inverter, though, how can anybody come up with a controlling PWM circuit?
__________________
  #6
Old 04-19-2008, 05:27 AM
Junior Member
Default
so what is the first step in making this project? developing first the inverter? before the PWM circuit? what do you think?
  #7
Old 04-19-2008, 02:20 PM
thingmaker3's Avatar
thingmaker3 thingmaker3 is offline
Super Moderator
Default
I suggest a "proof of principle" experiment would be the first step. Get a small AC motor and a battery or two. Build your PWM on that scale. If your principle can be demonstrated on a 12Vac motor, it may then be scaled up easily enough.
No point in spending extra money just because "someone" said it's possible. Miscommunication happens all the time.
__________________
"I want to establish in your mind very clearly that you must not think I deny all that I do not admit. On the contrary, I think there are many things which may be true, and which I shall receive as such hereafter, though I do not as yet receive them; but that is not because there is any proof to the contrary, but that the proof in the affirmative is not yet sufficient for me"
- Michael Faraday
  #8
Old 04-19-2008, 02:31 PM
beenthere's Avatar
Default
A note to the above suggestion: The AC motor you are going to try to control is an induction motor. A brush type universal motor is easily controlled by PWM, but will not demonstrate anything useful about controlling an induction motor. Experiment on a fractional horsepower AC induction motor.
__________________
  #9
Old 04-19-2008, 02:35 PM
Super Moderator
Default
Indeed! Kudos to Beenthere for catching my potentially expensive omission.
__________________
- Michael Faraday
  #10
Old 01-11-2009, 11:51 AM
casino casino is offline
To run a pump, you will probably want to get a sine wave inverter instead of the cheaper quasi-sine or square wave products. (the non-sine wave products are inefficient for running large motor loads and also very hard on the motors). A higher input voltage are more efficient. 220V inverters are common outside the US so getting one from a non-US vendor may be cheaper. For sizing, the inverter's peak power rating must be greater than the motor's LRA (locked rotor amps) * 220. It's best to size conservatively and aim for at least 1.5X the LRA. The continuous power rating of the inverter should be at least 20% higher than the RLA (running load amps) * 220. Some surplus UPS products also have suitable inverters and can be acquired very inexpensively on ebay, particularly since the 220/240V units are obscure in the US.
Tags
Related Site Pages
Section Title
Worksheet Digital-to-Analog conversion
Worksheet Design Project: Power inverter
Worksheet Power conversion circuits
Textbook Tesla polyphase induction motors : Ac Motors
Textbook Synchronous Motors : Ac Motors
Textbook Introduction : Ac Motors
Textbook AC voltmeters and ammeters : Ac Metering Circuits
Textbook Pulse Width Modulation : Dc Motor Drives
Textbook The "operational" amplifier : Operational Amplifiers
Video Lecture Linear Transistor Applications - Transistors and Transistor Circuits
Similar Threads
Thread Thread Starter Forum Replies Last Post
Using AC for a 220V DC solenoid DeMich General Electronics Chat 20 12-05-2013 12:37 AM
220V AC to 9V DC without using a trasnformer Ankon General Electronics Chat 4 06-02-2013 02:54 PM
ac to dc pwm voltage control raulchandna General Electronics Chat 3 11-25-2009 06:54 AM
Problem controlling a 220V AC Solenoid Valve with Relay and MCU. akirajunto The Projects Forum 6 10-30-2009 01:06 AM
I NEED A DC TO AC CONVERTER ( 150 w) 12V DC TO 220V AC Yeasina General Electronics Chat 2 05-05-2008 02:30 AM
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
