All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > General Electronics Chat
Notices
General Electronics Chat Discussion forum for general chat about anything electronics related, including asking questions about material in the All About Circuits E-book, Worksheets, and Videos.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 04-09-2008, 01:29 AM
Nara Shikamaru's Avatar
Nara Shikamaru Nara Shikamaru is offline
Member
Exclamation solving RLC circuits
hey everybody!!....sorry for the stupid question........Can you use Thevenin, Norton, superposition and Node analisys in RLC circuits???......if so....could you pass some examples circuits???......Thanks!!
  #2
Old 04-09-2008, 01:57 AM
hgmjr's Avatar
hgmjr hgmjr is offline
Super Moderator
Default
Quote:
The quick answer to your question is yes.
Do you have an example RLC that you are attempting to solve with any of the mentioned circuit analysis methods?
hgmjr
  #3
Old 04-09-2008, 02:06 AM
Member
Default
not really, im kind of studying for real circuits solving and designing!! and in all textbooks it appears that RLC circuits just can be solved by Phasors, complex math and Laplace transform!!....
and i wanted to know if you could solve them by Thevenin, Norton, superposition or Node analysis!!!........i dont have a particular circuit!!.....i was wondering if you all have RLC Circuits solve by any of those methods!!....thanks!!
  #4
Old 04-09-2008, 02:21 AM
hgmjr's Avatar
Super Moderator
Default
Here is a link to the wikipedia section on RLC circuits. If you scroll down a bit you will see the application of KVL to analyze a series RLC circuit in the frequency domain.
hgmjr
  #5
Old 04-09-2008, 04:15 AM
scubasteve_911 scubasteve_911 is offline
Default
The steps needed to fully understand a problem involving reactive components, initial conditions, or dependent sources need basic circuit theory coupled with a method to solve differential equations.
The simplest method is to learn to write your circuit in terms of the Laplace domain. Then, you apply your appropriate circuit theory to the problem and write equations. The next step, you "plug and play", as we call it, until the solution is found.
So, Laplace Circuit, circuit equation, isolate desired variable (current, voltage), inverse laplace for time domain solution.
Steve
  #6
Old 04-09-2008, 05:40 PM
Member
Default
for example.....i have this circuit i got from Industrial Electronics by Timothy Millman......can the components values be calculated using Nodal Analysis, or thevenin, or supersposition???..... would it be??.....what if i assume RL as a DC motor? (has some inductance and resistance).....so technically the circuit would have RLC components....
  #7
Old 04-09-2008, 06:00 PM
Default
Circuit design is about understanding component value consequences by writing reasonable (assumptions might be needed) equations about a particular circuit, then understanding the direct relationship of these values. In many cases, you will have to set a lot of these values to particular ratios and using your judgement to come to a conclusion.
What you are directly asking cannot be solved via normal circuit analysis tools. Whenever you have a device, such as a transistor or FET, you need to do two separate calculations. First, you need to find a DC solution, which will give rough biasing conditions for the devices. Secondly, you will need to do an AC analysis, which is crucial for understanding how your circuit will react (poles, transient response, etc).
In a lot of circumstances, FETs or transistors are simply modeled in two states if they are meant for cutoff/saturation operation. This can greatly simplify your solution..
Steve
  #8
Old 04-10-2008, 12:55 AM
hgmjr's Avatar
Super Moderator
Default
I see you have elected to cast a wider net from the RLC question mentioned in your initial post.
Scubasteve_911 is right. When you introduce components like the UJT and other similar active components you will need to replace them with a circuit model that uses conventional passive components along with dependent current sources and dependent voltages as appropriate to then make it possible to use conventional circuit analysis techniques.
hgmjr
  #9
Old 04-18-2008, 09:25 AM
Xolisa.X Xolisa.X is offline
Default
YES brother......Remember when you are solving complex wave you r using superposition bcz when u r calculate your impedance you use one source at a time
  #10
Old 03-15-2009, 12:38 PM
baby_vL's Avatar
baby_vL baby_vL is offline
Send a message via Yahoo to baby_vL
Default In RLC....
in RLC series, do VL and VC have any relationship 2 each other...???? (blur blur blur)
Tags
Related Site Pages
Section Title
Textbook Millman's Theorem revisited : Dc Network Analysis
Worksheet Millman's theorem
Textbook -Y and Y- conversions : Dc Network Analysis
Textbook Thevenin-Norton equivalencies : Dc Network Analysis
Textbook Norton's Theorem : Dc Network Analysis
Textbook Thevenin's Theorem : Dc Network Analysis
Textbook Superposition Theorem : Dc Network Analysis
Textbook Millman's Theorem : Dc Network Analysis
Similar Threads
Thread Thread Starter Forum Replies Last Post
Circuits Calculus Design!! Nara Shikamaru General Electronics Chat 9 04-18-2008 06:51 PM
Another question on telephone circuits... Externet General Electronics Chat 6 03-03-2008 04:53 AM
transient in RLC circuits vivian General Electronics Chat 1 10-06-2007 10:04 PM
RLC Circuits for waveform generation ryanrivera The Projects Forum 0 06-27-2007 01:41 PM
Solving Circuits davidand Homework Help 56 06-11-2005 06:43 PM
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
