All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > The Projects Forum
Notices
The Projects Forum Working on an electronics project and would like some suggestions, help or critiques? If you would like to comment or assist others with their projects, this is the place to do it.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 04-04-2008, 08:40 PM
rft rft is offline
Default Hall Effects Sensor as Voltage Divider
Greetings All,
I have a USB game controller that uses 10K conductive plastic pots that always need to be replaced. I wanted to replace these pots with the MAB25A Hall-Effects Sensors by Megatron; however, this sensor only have a single ended analogue output. My controller is expecting something similar to the voltage divider pot. How can I make this work?
I was even considering teaming an optical encoder with a digital pot.
Many thanks for your help and suggestions.
  #2
Old 04-04-2008, 09:29 PM
SgtWookie's Avatar
SgtWookie SgtWookie is offline
Expert Member
Default
Here's the link to a datasheet that I found:
http://www.megatron.de/export/DB_MAB25A_engl.pdf
Basically, you connect it the same way as you would the potentiometer - only in this case, you need to make sure that the Vsup pin is most positive, and the GND pin is connected to the most negative. Note that they only have two supply voltages available; 5 or 24.
If your game controller is a joystick, you probably will need replacement pots with a 90° travel.
A few years ago, I used a Clarostat Hall-effect digital pot to replace a bad throttle position sensor in a Jaguar for which the original part was no longer available. It had a 90° throw, and if I recall correctly, would work from various voltages; much more like a true pot. Such a device would likely work quite well in your application. They were rather expensive though, around $38 each.
Link:
http://www.alliedelec.com/Search/Sea...ary&Ntt=HRS100
(Correction - seems that it needed a 5V supply)
If these pots are to fix joysticks, you might consider using a GM-type throttle position sensor (TPS) which is a pot that has a 90° throw. You may be able to pick up a couple from a junkyard pretty cheaply.
__________________
General info:
If you have a question, please start a thread/topic. I do not provide gratis assistance via PM nor E-mail, as that would violate the intent of this Board, which is sharing knowledge ... and deprives you of other knowledgeable input.
  #3
Old 04-04-2008, 10:34 PM
rft rft is offline
Default
Thanks for your response; I will test tomorrow. Would you mind posting the throttle position sensor that you used for the Jaguar? At $38 each, this is a small price to pay to keep a machine running. My application is for steering using a 360deg pot. At mid range, the steering wheel is centered, towards the left is a left turn and opposite towards the right. I'm assuming a positive voltage for right, neg for left.
  #4
Old 04-05-2008, 12:37 AM
SgtWookie's Avatar
Expert Member
Default
I posted a link to Allied Electric's page that has a datasheet for the HRS100 pot which I used; $38 and change. Since you are using a steering wheel, perhaps a position sensor limited to 90° travel would not be appropriate; it could make it really hard to maintain control of your simulated vehicle. I suggest you go with your original 360° pot plan instead.
__________________
General info:
Tags
Related Site Pages
Section Title
Worksheet Linear computational circuitry
Textbook Brushless DC motor : Ac Motors
Worksheet DC transducers
Textbook Power measurement : Ac Metering Circuits
Textbook Computational circuits : Practical Analog Semiconductor Circuits
Worksheet Voltage divider circuits
Textbook The NOT gate : Logic Gates
Textbook Permeability and saturation : Magnetism And Electromagnetism
Similar Threads
Thread Thread Starter Forum Replies Last Post
Unsteady voltage divider? rougie The Projects Forum 9 10-30-2012 04:37 PM
E-book Help Voltage divider bias manulal General Electronics Chat 3 06-13-2012 05:18 AM
Info on using a voltage divider to measure higher voltage on a PIC18F Subterranean Embedded Systems and Microcontrollers 4 08-17-2010 01:17 PM
voltage divider or scaling problem stirling The Projects Forum 12 07-15-2010 10:06 AM
Voltage Divider Verification ELECTRONERD General Electronics Chat 52 09-21-2009 12:38 AM
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
