All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > General Electronics Chat
Notices
General Electronics Chat Discussion forum for general chat about anything electronics related, including asking questions about material in the All About Circuits E-book, Worksheets, and Videos.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 03-25-2008, 06:54 AM
KASHOKAN KASHOKAN is offline
Default What Is A Current Source?
what is a current source ?
As for as voltage source is concerned, it is a potential energy generated by Alternator,Battery etc.. and according to ohms Law I = V/R i.e if voltage increases current also increases.
I want to know, what is the principle involved in current sources, because i have seen in industry for testing the circuit breakers they use current sources to test for rated current carrying capacity,overload testing by injecting current.
i ,was told that the voltage in a current source is less and it is constant, then how come it can inject such a high capacity current.
K.Ashokan
  #2
Old 03-25-2008, 07:58 AM
gotumal's Avatar
gotumal gotumal is offline
Member
Default
Current sourse is nothing but sourses a constant curent irrespective of load (ofcourse there is a range) unlike a volateg sourse which sourses a constant voltage over a range of load resisatnces.
To test parameters associated with current can be tested with current sourses.
Aother example I can give is; to measure temperature with RTD. Since you have a constant current in RTD. A voltage accross it will be a proportional to the temperature.
__________________
- Gotumal
"I always win, except when I loose. But then I just don't count"
  #3
Old 03-25-2008, 11:37 AM
hgmjr's Avatar
hgmjr hgmjr is offline
Super Moderator
Default
Here is one section of the AAC ebook that talks about current sources.
If you read this section it will help put into context other replies to your question.
hgmjr
  #4
Old 03-27-2008, 04:46 PM
chrischristian chrischristian is offline
Junior Member
Smile Re: What is a current source
Hmm.., I don't know that you like this or not but then even let me try to explain this in a simpler manner by water analogy,
Say, you have a water tank which is punctured at a point, now if you put a finger or better say a pressure meter at the point the meter will show you how much water pressure is there in the water tank, it will definately very high as the hole is very small and as the area of the hole is small then definately there will be much preasure, now you can consider the water preasure as the voltage ( the preasure of the charge stored in the battery), the water that will be leaking through the hole is the amount of current which is very small as the hole is very small and the hole it's self is the resistance (the size of the hole decides the resistance caused to the flow of water) which is small. So, here we have a voltage source which always have a small input resistance (small hole) , small amount of current (flow of water) and high voltage preasure (preasure of water),
Now comming to the current source, it has very inverse situation , think that the hole is too much big so there will be large flow of water and the preasure will be too low as the area of the hole would be too big (with the increase of area preasure decreases),So, here we have a current source with high input resistance( big hole), high flow of current (water flow )and very low voltage preasure (water preasure).That is it, at least I have learend it this way!!, Hope will help.
  #5
Old 03-27-2008, 05:00 PM
recca02's Avatar
recca02 recca02 is offline
Default
http://en.wikipedia.org/wiki/Current...current_source
Tags
Related Site Pages
Section Title
Worksheet Elementary amplifier theory
Worksheet Passive integrator and differentiator circuits
Worksheet Capacitance
Worksheet Inductance
Textbook Computational circuits : Practical Analog Semiconductor Circuits
Textbook Special-purpose diodes : Diodes And Rectifiers
Textbook Quantum devices : Solid-state Device Theory
Textbook Bipolar junction transistors : Solid-state Device Theory
Textbook Nonlinear conduction : Ohm's Law
Textbook An analogy for Ohm's Law : Ohm's Law
Similar Threads
Thread Thread Starter Forum Replies Last Post
current controlled current source talhaali General Electronics Chat 2 06-13-2012 02:56 PM
Constant Current Source with Analog Modulation newothegreat The Projects Forum 6 05-04-2012 10:44 PM
Need Help to solve these three phase balanced load questions Ryza Homework Help 10 06-12-2011 02:46 PM
Current and voltage source jasonhaykin General Electronics Chat 9 04-16-2008 07:45 PM
About Thevenin Theorem BrillianceLin Homework Help 3 12-04-2007 05:42 PM
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
