All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > The Projects Forum
Notices
The Projects Forum Working on an electronics project and would like some suggestions, help or critiques? If you would like to comment or assist others with their projects, this is the place to do it.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 03-25-2008, 04:18 AM
dextrous dextrous is offline
Default Floating power supply
where are the floating power supplies used?
And in what way is it helpful in comparison with a normal grounded power supply?
  #2
Old 03-25-2008, 05:54 AM
Pich Pich is offline
Default
A floating power supply is a supply that has no reference point or common point.
Where either one of it's output +or- can be attached to any part of another circuit or other power supply and not cause a short. Floating power supplys are used in bias applications where the bias voltage needs to follows a variable voltage. A floating power supply can aso be imagined as a battery. and same rules can be applied.
  #3
Old 03-25-2008, 08:27 AM
studiot's Avatar
studiot studiot is online now
E-book Developer
Default
A battery in a flashlight is a floating power supply.
  #4
Old 03-25-2008, 04:40 PM
nomurphy's Avatar
nomurphy nomurphy is offline
Default
Try slogging your way thru this thread:
http://forum.allaboutcircuits.com/showthread.php?t=7805
Tags
Related Site Pages
Section Title
Worksheet Performance-based assessments for digital circuit competencies
Worksheet Multiplexers and demultiplexers
Worksheet Basic logic gate troubleshooting
Worksheet CMOS logic gates
Worksheet TTL logic gates
Worksheet Design Project: Logic probe
Worksheet Basic AC-DC power supplies
Textbook Basic gate function : Digital Integrated Circuits
Textbook Vacuum tube audio amplifier : Discrete Semiconductor Circuits
Textbook CMOS gate circuitry : Logic Gates
Similar Threads
Thread Thread Starter Forum Replies Last Post
7805 & 12VDC Power Supply Problem JDC The Projects Forum 10 10-24-2008 06:09 AM
Power problem...but not the power supply. BiggerBean Computing and Networks 15 05-22-2008 10:35 PM
Regulated Power Supply Help Dan. The Projects Forum 3 09-17-2007 07:06 AM
Convert PC Power Supply to Bench Supply Distort10n General Electronics Chat 3 04-04-2007 12:17 PM
Dc Transformerless Power Supply For A Fan Kenny The Projects Forum 5 09-18-2006 12:37 AM
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
