All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > Homework Help
Notices
Homework Help Stuck on a textbook question or coursework? Cramming for a test and need help understanding something? Post your questions and attempts here and let others help.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 03-24-2008, 07:30 PM
zbst zbst is offline
Cool Common Mode Output/OpAmp
I was given the following question on a homework assignment dealing with op-amps.
"Given an input of 0.1V DC with a gain of 10 and a common mode voltage of 0.009, what is the common mode output with a CMRR of 70dB? What is the total output voltage?"
So far, the only thing I have been able to calculate is the common mode gain, which has gotten me nowhere. I'm not even sure that part is correct, as I assume the gain of 10 the instructor gave us is a closed loop gain, and I was under the impression that open-loop gain was used in the following equation:
CMRR=20log(differential V gain/CM gain)
70 =20log(10/CM gain)
3.5 =log(10/CM gain)
10(to 3.5 power) =(10/CM gain)
CMgain=10/10(to3.5)
=0.0032
I have spent hours researching this question and am obviously missing something. Can anyone please help me figure out where I went wrong? Thanks!!
Last edited by zbst; 03-24-2008 at 07:35 PM. Reason: 10 raised to 3.5 power was unclear!
  #2
Old 03-24-2008, 11:59 PM
Distort10n Distort10n is offline
Default
Well...
Homework questions...professors and books really need to get it together. No circuit, no mention of supplies (single, dual), or configuration. However, since the gain is stated to be positive then I think it would be safe to say that the configuation is either a non-inverting or difference configuration. I vote for non-inverting.
A non-inverting op-amp with a gain of 10 and an input of 100mV will produce a 1V output ideally. You have a common mode voltage of 9mV and a CMRR of 75 dB.
So all you need to do is convert 75dB into an absolute number: 10^(75/20) and divide 9mV by the result.
Your final answer will be 1V + x, where x is the additional voltage offset from the common mode voltage.
  #3
Old 03-25-2008, 12:10 AM
Default
Thank you so much! I really appreciate your time on this one-our professor makes me feel completely stupid if I ask him anything, although I don't believe he means to do so. The assignment was hand-written by the professor and photocopied, and my class has had to make a lot of assumptions on various parts of it! Thanks again!
Tags
Related Site Pages
Section Title
Worksheet Differential transistor amplifiers
Worksheet AC negative feedback opamp circuits
Worksheet Linear computational circuitry
Worksheet Summer and subtractor opamp circuits
Worksheet Inverting and noninverting opamp voltage amplifier circuits
Worksheet Negative feedback opamp circuits
Worksheet Magnetic units of measurement
Textbook Practical considerations : Operational Amplifiers
Video Lecture Decibels - Amplifier Basics - Transistors and Transistor Circuits
Textbook Amplifier gain : Amplifiers And Active Devices
Similar Threads
Thread Thread Starter Forum Replies Last Post
Using a PNP common Collector to drive a relay cork_ie The Projects Forum 4 05-12-2013 12:35 AM
Appreciate help with OP amp and Av Diff and Av Common mode RyanKim Homework Help 4 01-06-2013 11:55 AM
common mode lost in analog General Electronics Chat 3 09-26-2005 09:19 PM
Common Mode Rejection (CMR) magnet Homework Help 9 05-22-2005 06:56 PM
Common mode voltage Coz General Electronics Chat 1 05-14-2005 04:05 PM
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
