Dear All,
I am very new to all this. I want to build my own arduino relay switch board using this Solid State Relay
http://www.omron.com/ecb/products/pdf/en-g3vm_351b_e.pdf
I found this circuit
https://www.circuitlab.com/circuit/49xj2t/relay-shield-circuit/
My questions are:
1) Can this solid state relay work as a normal relay board?
2) how can I specify the require "transistor" and "diode" voltage/resistance to use with the relay ic?
3) any help or feedback on the circuit and the best way to do it, i'd really appreciate it.
Thank you
My questions are:
Thank you
