Hi everyone,
I'm working with a linear actuator on a bigger mechanical project, and since I've never worked with them I'd like to have some explanation on them.
It has a potentiometer inside, to sense it's position.
How the potentiometer actually works inside? And how it is connected? It has power supply +5V, gnd, and then the output with the read value.
I have two of them and after few minutes of tests the potentiometers stopped working.
I explain better:
I pushed the actuator all the way out, and let him rotate freely for some seconds. It could be possible that this caused the potentiometer run out of scale?
This is the datasheet
http://www.thomsonlinear.com/downloads/actuators/Max_Jac_bruk.pdf
Any other idea of any cause for the potentiometer stop?
I explain better:
