All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > General Electronics Chat
Notices
General Electronics Chat Discussion forum for general chat about anything electronics related, including asking questions about material in the All About Circuits E-book, Worksheets, and Videos.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 03-12-2008, 03:42 PM
will1234 will1234 is offline
Default Step Down Transformer
Anyone,
I have a 6500vac (as best as I can tell 7 ma) bug zapper transformer and I need to step it down to about 1200vac before converting it to DC. I believe it would be a 6:1 ratio??? I think I remember reading somewhere that stepping down would lower the voltage but also increase the Ma. I would like to increase the current but must lower the voltage.
So, the simplest first: Would any place have a 'stock' transformer that would get me near where I need to be? Maybe a doorbell transformer run backward??
Is there some place either online or other that would likely have a true step down transformer that would work?
Last resort, is winding your own step down transformer a difficult task? Is there a web site that anyone knows of that I could use to determine the specific details to wind a transformer like I need??
As always, I appreciate any guidance anyone can give me.
Will
  #2
Old 03-12-2008, 03:50 PM
beenthere's Avatar
beenthere beenthere is offline
Default
That would be a 3:1 ratio.
It might be easier to simply pervert a step-down transformer. A 12 volt secondary is 1/10 the 120 VAC input. So, placing the 120 VAC to the 12 volt winding should give you close to 1200 VAC out. Make sure the transformer has a hipot rating of at least 5000 volts before you try this.
Please be very careful around high voltages.
  #3
Old 03-12-2008, 10:35 PM
lilfrankywilding lilfrankywilding is offline
Default yo wassup dog
its a 5.4 to one ratio man! where do you see three to one
  #4
Old 03-12-2008, 11:24 PM
beenthere's Avatar
Default
Carry over from the previous answer I posted.
  #5
Old 03-18-2008, 11:44 PM
Default
Looking on DigiKey, Mouser, and assorted other sites I can find 12 volt step down transformers which make no mention of hipot so I have to assume that they aren't. Does anyone know where I might have better luck finding a hipot step down? Is there anything in everyday life that would have one I could cannibalize?
  #6
Old 03-19-2008, 01:27 AM
SgtWookie's Avatar
SgtWookie SgtWookie is offline
Expert Member
Default
Instead of trying to step down your "bug zapper", why not try building your own flyback transformer & associated circuitry?
Here's a good & informative "how to" page on that very subject:
http://www.dos4ever.com/flyback/flyback.html
Even gives a "how to" on building an inductor test bench.
Just be really careful to not zap yourself or your equipment. Read & heed the safety tips.
__________________
General info:
If you have a question, please start a thread/topic. I do not provide gratis assistance via PM nor E-mail, as that would violate the intent of this Board, which is sharing knowledge ... and deprives you of other knowledgeable input.
  #7
Old 03-19-2008, 06:18 PM
Default
I'll give this a try, thanks. Concerning the transformer I was trying to find a 12v step down that I could run backwards on 110v and get into the 1200v range that was suggested above. Finding one that is hipot that wouldn't melt down is the problem I dealing with.
  #8
Old 03-19-2008, 06:46 PM
SgtWookie's Avatar
Expert Member
Default
Yes, the hipot is definitely a problem.
But, there's no reason you can't scavenge and wind one yourself.
Be sure to insulate well between the layers of secondary windings, or there will be a bright flash and smoke in your future.
__________________
General info:
  #9
Old 03-23-2008, 11:34 PM
Xray Xray is offline
Member
Default
Quote:
Just so I understand what you are asking.... You want to run 120 VAC into the 12 VAC winding so that you can get 1200 VAC ouput on the secondary (which WAS the 120 VAC primary)? If that's what you are asking, then NO, it will not work! You will smoke your transformer, and probably pop the circuit breaker that protects that particular circuit. The reason why it won't work is because the inductance is much too low on the 12 Volt winding to put 120 Volts into it. And even it it did not smoke, 1200 volts would likely arc across the windings like crazy and burn out the transformer that way.
  #10
Old 03-24-2008, 10:06 AM
recca02's Avatar
recca02 recca02 is offline
Default
Using a low rated transformer can be a problem as..
connecting 1200 V to some low resistance system(simply high power device) will send a huge current.
then there is the insulation problem 1200 volts might overcome the insulation and there will be current in the entire core of the transformer( perhaps even body) and possibly lot other problems..
Tags
Related Site Pages
Section Title
Video Lecture Transformers (Part 1) - Inductors,Capacitors,Transformers
Worksheet AC metrology
Worksheet Impedance matching with transformers
Worksheet Autotransformers
Worksheet Step-up, step-down, and isolation transformers
Textbook Step-up and step-down transformers : Transformers
Textbook Winding configurations : Transformers
Textbook Special transformers and applications : Transformers
Textbook Build a transformer : Ac Circuits
Textbook Transformer -- power supply : Ac Circuits
Similar Threads
Thread Thread Starter Forum Replies Last Post
step down transformer ashlyn37 The Projects Forum 3 06-29-2014 07:02 PM
Help Please - Step Down Transformer Is Still Tripping The Breaker SyY The Projects Forum 31 09-14-2009 02:36 AM
Full-Wave Bridge Rectifier Filter + Regulator DC Power supply Petrucciowns Homework Help 52 07-10-2009 05:30 PM
problem with Oscillator and step up transformer badrove The Projects Forum 6 04-10-2008 09:40 AM
transformer response to a step input AlexK General Electronics Chat 2 06-04-2007 07:58 PM
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
