So the goal of this project is to build portable speaker (0.5w-1w) fed by internal li-po battery and charged by USB. i will use 5v step-up converter or not depending on amplifier IC.
and this is the first point of this thread. after looking for some amplifier datasheets i found this perfect one LM831 where with 3v you can get 440 mW power output, wich is the best i've found. and with 5v you can go up to 0,9W.
datasheet :http://www.ti.com/lit/ds/symlink/lm831.pdf
the thing is i cant find it anywhere!! its obsolete and for some reason its not in market anymore...and i also couldnt find anything similar to this... lm836 is not even close to this. can someone help me here with something this good on market?
also... on ebay i found this
http://www.ebay.com/itm/LM831N-DIP-16-N-A-1-Pcs-/121129845100?pt=LH_DefaultDomain_0&hash=item1c33e6c16c
do you guys think this is reliable?? many thanks in advance
