All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > General Electronics Chat
Notices
General Electronics Chat Discussion forum for general chat about anything electronics related, including asking questions about material in the All About Circuits E-book, Worksheets, and Videos.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 03-05-2013, 09:46 AM
Aggie Aggie is offline
New Member
Default Timer delay with relay on for 4 seconds
Need help with a circuit design which can fulfill the below mentioned criteria:
Circuit status is normal when power on, when triggered (through a magnetic contact switch by opening a door) should start a timer delay for 15 seconds, on expiry of the delay the relay should come on for 4 seconds, and then circuit should back in normal status. during the course of the 15 seconds timing delay a reset should also be available to bypass the relay on for 4 seconds.
thanks
  #2
Old 03-05-2013, 09:56 AM
thatoneguy's Avatar
thatoneguy thatoneguy is offline
Senior Member
Default
Need translation to exact terms.
  • On trigger, delay of 15 seconds is started.
  • At end of 15 seconds, a high level is output for 4 seconds.
  • If trigger occurs during the 4 second high level output, the output is delayed an additional 4 seconds.
The high output can activate a relay, turn on a light or buzzer, etc.
Is this correct?
  #3
Old 03-05-2013, 11:58 AM
New Member
Default
Ok I need a simplest circuit to do the following, I need to monitor a vault door with the following logic.
Step 1. Door opened (entry) - start of timer delay for 15 seconds,
Door closed (Still inside vault) - timer still running.
Step 2. Reset Timer with reset switch.
Step 3. Door Open (Exit) - Start of timer delay for 15 seconds,
Door closed - timer auto reset.
The above step are executed under normal circumstances.
If under duress, the reset switch is not pressed and the relay should activate on the expiry of the 15 seconds delay just for 4 seconds to trigger an alarm and reset itself to normal state. so the cycle can be repeated on.
Hope this helps
  #4
Old 03-05-2013, 02:03 PM
tracecom's Avatar
tracecom tracecom is offline
Senior Member
Default
The simplest circuit would involve a microcontroller. Is that an acceptable option?
  #5
Old 03-05-2013, 09:32 PM
ScottWang's Avatar
ScottWang ScottWang is online now
Senior Member
Default
If your description more clearly as set to hi or low when door open or close, maybe it can using CD4017 and NE555, it just maybe.
  #6
Old 03-06-2013, 05:15 AM
New Member
Default
A microcontroller or CD4017 and NE555, options are acceptable, please guide me if any circuit is available which fulfills the criteria.
Thanks
  #7
Old 03-06-2013, 07:23 AM
New Member
Default
Normal operation condition
Door open (Entry Trigger) starts a timer delay low state for 15 seconds, Door close (once inside), Timer is Reset with a reset switch before expiry of 15 seconds, Awaiting trigger, Door open (Exit Trigger) starts a timer delay of Low state for 15 seconds, Door closed before the 15 seconds delay expires (exit complete) Auto reset, Awaiting next Door open (Entry trigger).
Under Duress conditions
Door open (Entry Trigger) starts a timer delay low state for 15 seconds, Door open / close (once inside), Timer expires after 15 seconds timer delay(Timer not reset), Output goes High State (triggers Relay) Relay remains on for 4 seconds, then auto resets timer, Awaiting trigger, (Door open)
Please help!!!
  #8
Old 03-06-2013, 09:56 AM
ScottWang's Avatar
Senior Member
Default
Door open (Entry Trigger) -- Hi or Low?
Door open (Exit Trigger -- Hi or Low?
Door close (once inside) -- Hi or Low?
Timer is Reset -- Hi or Low?
(exit complete) Auto reset -- Hi or Low?
auto resets timer -- Hi or Low?
If you describe as below and also labeled the Hi or Low, it will more easier to understand.
1. ....
2. ....
3. ....
4. ....
Tags
Related Site Pages
Section Title
Worksheet Time-delay electromechanical relays
Worksheet Flip-flop circuits
Worksheet Timer circuits
Worksheet Electromechanical relay logic
Worksheet CMOS logic gates
Worksheet Insulated gate field-effect transistors
Textbook The S-R latch : Multivibrators
Textbook Programmable logic controllers : Ladder Logic
Textbook Digital logic functions : Ladder Logic
Textbook Time-delay relays : Electromechanical Relays
Similar Threads
Thread Thread Starter Forum Replies Last Post
making a delay off timer sdowney717 General Electronics Chat 12 09-09-2013 01:44 PM
5 sec delay ON timer YeloBlammo The Projects Forum 3 11-13-2012 08:58 PM
Delay timer with BJT and Relay masCh The Projects Forum 9 10-29-2012 12:11 AM
Help ....Temperature Sensor Zevoic General Electronics Chat 5 12-31-2011 08:27 PM
Simple 555 timer delay on circuit needed eatumup General Electronics Chat 3 02-21-2008 04:21 AM
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
