All About Circuits Forum
Go Back   All About Circuits Forum > Abstract Forums > Physics
Notices
Physics Discussion forum for anything physics related.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 01-20-2012, 04:51 PM
logearav logearav is offline
Senior Member
Default Force between two current carrying conductors
Revered Members,
In the case of two parallel current carrying conductors placed at a distance 'x' apart, the force is attractive if the current flows in the same direction in both the conductors and its repulsive when current flows in opposite direction. How the direction of current determines if the force is repulsive or attractive?
  #2
Old 01-20-2012, 05:02 PM
Kermit2's Avatar
Kermit2 Kermit2 is offline
Senior Member
Default
The field is circular around a conductor and would have a direction of clockwise or counter clockwise. Magnets attract opposite poles.
two clocks next to each other.
The pole is the arrow of direction of movement.
The head of the arrow will be North is this example.
The arrow around both conductors points to the right.
The arrow around the left conductor will point at the tail of the arrow around the right conductor.
The 'magnets' are showing opposite poles to each other and the wires are pulled together.
__________________
I'm too old.
  #3
Old 01-20-2012, 05:35 PM
hexreader's Avatar
hexreader hexreader is offline
Senior Member
Default
Interesting question, and I really like your explanation but....
What you say holds true when both clocks are at 12 O'Clock and 6 O'Clock.
What about when the left hand clock is at 3 O'Clock and the right hand clock is at 9 O'Clock ? (the mid point between the two wires). Won't repulsion occur?
Does the 12 and 6 "opposites attract" effect over-power the 3 and 9 repulsion effect?
... or do I completely misunderstand?
I know you are right, but I struggle to understand the details.
EDIT: I think I found the answer for myself here:
http://webphysics.davidson.edu/physl...orcewires.html
And I think my guess was right
  #4
Old 01-20-2012, 06:47 PM
Kermit2's Avatar
Senior Member
Default
If we try using the magnetic and electric circuit analogy
the magnetic field will try to establish itself along the path of least resistance. (reluctance I believe is the proper analogous unit)
So the point of 3 o'clock and 9 o'clock on the conductors(between them) would represent a zone with a very high resistance to the formation of the magnetic field due to the conflicting directions of field orientation there. While on the opposite sides, or the outer edges of the conductors the field direction is the same as it is for a single conductor. This establishes the path around the outside of the two conductors as the path of least resistance and the magnetic force is concentrated there.
The result is the forcing together of the conductors due to magnetic attraction. The attraction is the result of the field assuming its most compact form, and also, the shortest route that closes back upon itself (a circle in this case) and dragging the conductor from which it emenates along with it. With two conductors magnetic fields trying to assume the same path, the conductors themselves also try to occupy the same physical space, to make it possible. We call it attraction.
__________________
I'm too old.
  #5
Old 01-20-2012, 07:45 PM
hexreader's Avatar
Senior Member
Default
@Kermit2
Another impressive explanation, which solves the mystery for me. Many thanks.
Hope it benefits the OP too
Tags
Related Site Pages
Section Title
Worksheet AC motor theory
Worksheet Capacitance
Worksheet Intermediate electromagnetism and electromagnetic induction
Worksheet Basic electromagnetism and electromagnetic induction
Video Lecture Magnetism and Electromagnetism - Basic Electronics and Units of Measure
Video Lecture Electrical Quantities A - Basic Electronics and Units of Measure
Textbook Electric fields and capacitance : Capacitors
Textbook What is a meter? : Dc Metering Circuits
Textbook Voltage and current : Basic Concepts Of Electricity
Textbook Static electricity : Basic Concepts Of Electricity
Similar Threads
Thread Thread Starter Forum Replies Last Post
Need Help to solve these three phase balanced load questions Ryza Homework Help 10 06-12-2011 02:46 PM
LED driver manuel09 General Electronics Chat 12 05-02-2010 07:34 PM
Common Emitter Amp Design hydra504 Homework Help 7 06-30-2009 05:43 AM
Force produced by current carrying coil to the sludge(Steel rod). rvb53 Homework Help 32 06-26-2008 02:31 PM
Electrostatics - Current!, Convection & Conduction part 1 Nirvana Physics 3 09-11-2007 09:57 PM
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
