All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > Homework Help
Notices
Homework Help Stuck on a textbook question or coursework? Cramming for a test and need help understanding something? Post your questions and attempts here and let others help.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 05-30-2013, 09:08 AM
ammar shamsi ammar shamsi is offline
New Member
Default Solar Charge Controller
Please Suggest,
I am designing a solar charge controller , I want to make common
ground of solar panel & battery and switching(Disconnect on full charge or PWM to control current) h-side i.e positive
terminal of the solar Panel by using a MOSFET,
The problem I m facing is that the I don't have sufficient Gate voltage to properly tun On the MOSFET becouse the Mosfet source is +Vbat i.e 12V above the ground.
I have found there are some driver ICs based on charge pump.
Please provide economical and reliable solutions.
Thanks
  #2
Old 05-30-2013, 01:08 PM
Dodgydave's Avatar
Dodgydave Dodgydave is online now
Senior Member
Default
Already answered
__________________
NECESSITY IS THE MOTHER OF INVENTION !
The Following User Says Thank You to Dodgydave For This Useful Post:
ammar shamsi (05-31-2013)
  #3
Old 05-30-2013, 08:49 PM
WBahn WBahn is offline
Senior Member
Default
Quote:
Originally Posted by ammar shamsi View Post
Please Suggest,
Thanks
Let me make sure I have this right. You say that YOU are designing something for a problem that is posted in the Homework Help forum, but you want US to provide "economical and reliable solutions" for you.
Hmmm.....
No.
Now, if you post YOUR attempt to solve YOUR problem, we would be more than happy to assist YOU find YOUR way to a solution to YOUR problem.
Tags
Similar Threads
Thread Thread Starter Forum Replies Last Post
How Best to charge 12V battery from Solyndra solar tubes? madmadscientist The Projects Forum 19 05-09-2013 07:58 PM
PWM Charge Controller - Pulse Width? Buchy The Projects Forum 5 07-18-2011 11:43 PM
NuBie- Solar Charge Controller assistance/advice btrapr The Projects Forum 0 08-10-2010 01:31 AM
charge controller Northtexasengineer The Projects Forum 3 04-16-2010 04:30 PM
Low-voltage charge control for solar Kefka666 The Projects Forum 7 11-11-2008 12:50 PM
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
