All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > General Electronics Chat
Notices
General Electronics Chat Discussion forum for general chat about anything electronics related, including asking questions about material in the All About Circuits E-book, Worksheets, and Videos.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 10-19-2011, 05:58 AM
TimCollins TimCollins is offline
New Member
Default How to determine AC/DC
I have a question. I have a small electric motor out of an old jukebox that I think is bad. I found the wiring diagram telling me the motor circuit is 28VDC. However, before I found the diagram I was using a voltmeter testing the plug into the motor and I got about 30VDC however, when I switched the voltmeter to AC I also got a reading of about 13.5VAC. So... my question is, if I did not have the wiring diagram how would I know whether the circuit was AC or DC because I am getting what looks like valid readings from both on my meter?
Thanks in advance for any help...
  #2
Old 10-19-2011, 06:06 AM
SgtWookie's Avatar
SgtWookie SgtWookie is offline
Expert Member
Default
Do you have a couple of LEDs and a 1/4W 5.6k resistor?
If so, wire the LED's back-to-back (anode to cathode, cathode to anode) in parallel, and the 5.6k resistor in series with them.
Then connect that across the voltage.
If both LEDs light, then it's AC. If only one lights, it's DC.
__________________
General info:
If you have a question, please start a thread/topic. I do not provide gratis assistance via PM nor E-mail, as that would violate the intent of this Board, which is sharing knowledge ... and deprives you of other knowledgeable input.
The Following User Says Thank You to SgtWookie For This Useful Post:
PackratKing (10-20-2011)
  #3
K7GUH K7GUH is offline
Senior Member
Default
You could look at the waveform at various points in the circuit, using an oscilloscope. Otherwise, you may have to do a lot of guesswork. I should think that a pulsating d.c. current would give you both d.c. and a.c. readings on some types of meter.
  #4
Old 10-19-2011, 06:38 AM
SgtWookie's Avatar
Expert Member
Default
Oscilloscopes are great - if you happen to have one. Since this board is oriented towards beginning to intermediate level hobbyists, most of the members won't have an O'scope handy.
A couple of LEDs and a resistor is pretty low tech, but it's cheap, easy, and will get the job done.
__________________
General info:
  #5
Old 10-19-2011, 01:32 PM
New Member
Default
Thanks for your answers. I was hoping there was an easy way that maybe I just didn't know about. But, you have answered my question. Thanks!
  #6
Old 10-19-2011, 05:32 PM
colinb colinb is offline
Senior Member
Default
Maybe the ac voltage is actually a result of the back emf produced by the motor.
Did you measure the 30 V dc / 13.5 V ac with the motor connected and running? Try measuring the voltage with the motor disconnected so that back emf is not a factor. And/or try measuring the voltage with the motor connected but stalled (hold the rotor stationary).
  #7
Old 10-20-2011, 12:17 PM
THE_RB's Avatar
THE_RB THE_RB is offline
Senior Member
Default
The "old jukebox" may be running the DC motor from rectified AC but with no filter caps. That was common in some 1950's equipment, I have a 1950's battery charger that does the same thing.
__________________
Roman Black - PICs and electronics. Author of BTc PIC-sound encoder, Shift1-LCD project, the TalkBotBrain talking PIC controller, LiniStepper open-source microstepping motor driver, the Black Regulator 2-transistor SMPS, and probably some other stuff; www.RomanBlack.com
Tags
Related Site Pages
Section Title
Worksheet Rectifying diodes
Worksheet Basic oscilloscope operation
Textbook The Silicon-Controlled Switch (SCS) : Thyristors
Textbook The Silicon-Controlled Rectifier (SCR) : Thyristors
Textbook Thyristors : Solid-state Device Theory
Similar Threads
Thread Thread Starter Forum Replies Last Post
AC/DC converter nathomas General Electronics Chat 5 04-07-2011 08:45 PM
AC/DC Relay Board used Via Float S/ to control pump help needed :) MaxPower1 The Projects Forum 0 01-29-2011 06:59 PM
Want to make AC/DC motor reversible op4wd1 The Projects Forum 1 11-19-2010 10:29 PM
Will this AC/DC adaptor work for a network router? expat98 General Electronics Chat 4 04-14-2005 03:23 AM
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
