All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > General Electronics Chat
Notices
General Electronics Chat Discussion forum for general chat about anything electronics related, including asking questions about material in the All About Circuits E-book, Worksheets, and Videos.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 05-15-2014, 07:51 PM
tadm123 tadm123 is offline
Junior Member
Default Capacitors on AC
I know the capacitor blocks DC and passes AC.
My question is in AC, The capacitor charges in the positive cycles and discharges in the negative cycles? Or the discharging begins from the peaks towards 0 and similarly in the other cycle from the negative peak to 0?
This concept seems a little bit tedious to understand and I'm probably looking too much into it. Can anyone explain me the process in a simpler way? Thanks a lot.
  #2
Old 05-15-2014, 08:21 PM
#12's Avatar
#12 #12 is offline
Senior Member
Default
Take one circuit at a time because mixing the two concepts makes it more complicated than it needs to be.
A capacitor can be charged with a DC voltage.
When you use it as a connection between an AC source and a load, the capacitor has an impedance related to frequency. If the impedance of the capacitor is small compared to the impedance of the load, very little voltage will be observed across the terminals of the capacitor. In a sense, the capacitor does NOT charge up in this AC circuit.
If the impedance of the capacitor at today's frequency is large compared to the load, the voltage across the capacitor terminals will be significant and it will be a simple sine wave if the load is a resistor. Whenever there is a voltage across a capacitor, you can say it is "charged" to some amount, but an AC circuit will have the charge continuously changing.
Continuous. The capacitor doesn't wait for a while to discharge. It is a passive component and it allows current to flow continuously, depending on the frequency, the load, and the wave shape you apply to it.
__________________
It's only my opinion, and sometimes I'm wrong.
(I learn something almost every day on this site.)
  #3
Old 05-15-2014, 08:22 PM
Veracohr Veracohr is offline
Senior Member
Default
Q = CV
Q = charge
C = capacitance
V = voltage
A capacitor with 0V across it has no charge, no stored energy. A capacitor with other than 0V across it has charge, has energy stored in an electric field, regardless of the polarity of the voltage.
  #4
Old 05-16-2014, 02:09 AM
Brownout's Avatar
Brownout Brownout is offline
Senior Member
Default
Think of an hour glass. If you turn it on one side, sand will flow through it until one end is empty and the other end is filled. This is the DC equivalent, where charge flows into a capacitor until one end is full and the other is empty. Now, consider an hour glass which is continually turned over. Sand will flow as long as you keep flipping it. This is the equivalent to the AC case, where current flows continuously.
__________________
My mind is aglow with whirling, transient nodes of thought careening through a cosmic vapor of invention. ~Hedley Lamarr
  #5
Old 05-16-2014, 10:14 PM
profbuxton profbuxton is offline
Junior Member
Default
Please note, I do not believe that current "flows through a capacitor". It is a "open circuit". When volts are applied a charge build up on the plates in a particular direction (depending on polarity of volts). When volts are reversed(as in AC case) charge is reversed in polarity. This occurs via the external circuit loop.
You can charge a cap with DC through a resistor and measure charging current. If you then switch the charging volts polarity cap will discharge and build up charge in other polarity. If you do this very rapidly and measure charging current it will appear as if cap is passing current. This is what happens in AC circuits.
The Following User Says Thank You to profbuxton For This Useful Post:
MaxHeadRoom (05-16-2014)
Tags
Related Site Pages
Section Title
Video Lecture Capacitors (Part 2) - Current Flow in a Capacitive Circuit - Inductors,Capacitors,Transformers
Worksheet Switched capacitor circuitry
Worksheet Capacitive reactance
Textbook AC voltmeters and ammeters : Ac Metering Circuits
Textbook The Silicon-Controlled Rectifier (SCR) : Thyristors
Textbook Gas discharge tubes : Thyristors
Textbook An electric pendulum : Resonance
Video Lecture Power Supplies - Applications - Diodes and Diode Circuits
Textbook Biasing techniques : Bipolar Junction Transistors
Textbook Clamper circuits : Diodes And Rectifiers
Similar Threads
Thread Thread Starter Forum Replies Last Post
Types of Capacitors and their selection SPQR General Electronics Chat 3 01-25-2013 12:58 PM
AC capacitors or DC capacitors? onlyvinod56 The Projects Forum 1 01-14-2013 01:12 PM
A basic question about capacitors in AC circuits boogie General Electronics Chat 16 08-28-2012 04:04 AM
Ac input, frequency, and capacitors size suggestions? soeury0914 The Projects Forum 3 10-24-2010 05:36 AM
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
