All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > Homework Help
Notices
Homework Help Stuck on a textbook question or coursework? Cramming for a test and need help understanding something? Post your questions and attempts here and let others help.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 04-25-2011, 03:01 PM
E&C Genius E&C Genius is offline
Junior Member
Default Input Bias Current & Offset Voltage measurement of an op amp
I want to measure the Input Bias Current and the Offset Voltage of an op amp for my electronics lab experiment. I tried to design a circuit for that purpose but it didn't work on (Multisim software), so obviously I didn't build it.
I've found this PDF online; and as you can see on page 4 it suggest a way to measure them. But I couldn't understand how exactly can I do it?
Please help me with a suitable circuit or an explanation for the one in the PDF.
Thank you.
  #2
Old 04-25-2011, 03:09 PM
beenthere's Avatar
beenthere beenthere is offline
Senior Member
Default
Figures 4 & 5 in the article describe how to measure the input bias current. It looks as if all you need to do is to duplicate the setups given in the file. really nothing to design.
Can you be specific about what is causing you difficulty?
__________________
First comes the hardware, then the software.
  #3
Old 04-25-2011, 10:23 PM
wmodavis wmodavis is offline
Senior Member
Default
The basic problem of measuring input bias current is:
Because these bias currents are so miniscule they defy direct measurement. You cannot simply insert an ammeter in series and get the measurement you want because the currents are virtually zero compared to those we usually measure. Just try to find a femto-ammeter. Therefore it must be measured indirectly and determined by calculation. Accuracy of the determination is dependent on many factors which must be carefully and accurately measured and controlled.
Good luck.
Tags
Related Site Pages
Section Title
Worksheet Linear computational circuitry
Worksheet Ammeter design
Textbook Practical considerations : Operational Amplifiers
Worksheet Basic ammeter use
Video Lecture Op Amps Characteristics (Part 2) - Internal Circuitry - Op Amps and Op Amp Circuits
Textbook Integrator : Analog Integrated Circuits
Textbook The common-base amplifier : Bipolar Junction Transistors
Textbook Make your own multimeter : Dc Circuits
Textbook Ammeter impact on measured circuit : Dc Metering Circuits
Textbook Ammeter design : Dc Metering Circuits
Similar Threads
Thread Thread Starter Forum Replies Last Post
Is differential op amp the way to go DonRecardo General Electronics Chat 2 12-11-2010 02:19 AM
Using Thevenin with Op amp. sn00py23 Homework Help 59 03-08-2010 11:05 AM
quick check ihaveaquestion Homework Help 23 05-07-2009 09:00 PM
Current and Voltage measurement with Embedded system triplehdineshbabu Embedded Systems and Microcontrollers 4 02-24-2009 01:16 PM
Impedance measurement with high voltage DC bias PePu The Projects Forum 0 02-09-2009 06:05 AM
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
