All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > General Electronics Chat
Notices
General Electronics Chat Discussion forum for general chat about anything electronics related, including asking questions about material in the All About Circuits E-book, Worksheets, and Videos.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 03-21-2010, 05:15 PM
twomilimeter twomilimeter is offline
New Member
Default What is characteristic impedance?
Based on my understanding, characteristic impedance is the constant and instantaneous impedance a signal sees as it travels along a transmission line. If the impedance along the line is different, then the voltage will get reflected. But
[1] what is causing the voltage to be reflected?
[2] has characteristic impedance related to the resonant in the LC circuit?
[3] is it necessary that the transmission line be purely resistive or could it be a combination of RLC network that form a 50ohm impedance line?
Kindly advise and thank you for the help.
Twomilimeter
  #2
Old 03-21-2010, 05:55 PM
rjenkins rjenkins is offline
Senior Member
Default
Have a look here for some basic info:
http://en.wikipedia.org/wiki/Characteristic_impedance
Think of a single pulse of power, and what voltage that equates to on a single resistor.
For the same power, a higher resistance needs higher voltage or a lower resistance needs lower voltage.
Now think of that pulse travelling along a coaxial cable. If the impedance suddenly changes the voltage must change to suit. If the impedance gets higher, more voltage is needed and a negative reflection will go back down the cable. If the impedance gets lower, a positive reflection occurs. The amplitude of reflection depends on the amount of impedance change.
To visualise this, think of a single wave or ripple travelling down a canal with perfectly even sides. If the canal suddenly gets wider or narrower, a wave is reflected back, either a dip or bump (negative or positive) in the surface.
A transmission line can be modelled as repeated descrete sections with capacitance & inductance (and resistance, though that is not needed to set the impedance).
__________________
Robert Jenkins.
Tags
Related Site Pages
Section Title
Textbook Waveguides : Transmission Lines
Textbook Impedance transformation : Transmission Lines
Textbook Standing waves and resonance : Transmission Lines
Textbook ``Long'' and ``short'' transmission lines : Transmission Lines
Textbook Finite-length transmission lines : Transmission Lines
Textbook Characteristic impedance : Transmission Lines
Textbook A 50-ohm cable? : Transmission Lines
Worksheet Characteristic Impedance
Textbook Biasing techniques : Bipolar Junction Transistors
Textbook Special-purpose diodes : Diodes And Rectifiers
Similar Threads
Thread Thread Starter Forum Replies Last Post
Clarification on "source resistance" (or impedance)? Mike33 General Electronics Chat 6 01-28-2010 12:39 PM
Characteristic Impedance of Coax Pavlo138 Radio and Communications 7 12-31-2009 11:12 PM
Impedance??? lifeisworld Homework Help 0 09-28-2009 08:26 PM
Flip Flop Characteristic Equations n0th1n2b3sa1d Homework Help 5 05-27-2009 04:46 PM
hybrid coupler characteristic impedance erumai General Electronics Chat 1 10-08-2007 05:52 PM
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
