All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > The Projects Forum
Notices
The Projects Forum Working on an electronics project and would like some suggestions, help or critiques? If you would like to comment or assist others with their projects, this is the place to do it.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 10-02-2012, 04:58 PM
Shozzza Shozzza is offline
New Member
Default Using a linear CCD array
Hello AAC users, this is my first post here, very interested in electronics and hope to learn alot during my time here.
Doing a little physics project at university and i've been given a Toshiba TCD102D CCD Linear Image Sensor to use. (Also have access to a USB CCD but almost 100% would need to use the TCD102D Linear 2048 x 1 pxl)
CCD LINK 1 - http://www.alldatasheet.com/datashee...C/TCD102D.html
CCD LINK 2 - http://elcodis.com/parts/5774396/TCD102D.html
In short I want to use it to view a spectrum of diffracted visible light in real time on a computer, I need to connect it to a computer but cannot find out how to use it as the supplied sheets are too technical for me and my supervisor.
I understand I will need to use something like, PIC's, ADC's, EPP links?, Asynchronus Ethernet boards, etc to communicate with the computer.
I have come across information advising on connecting it to the printer port or serial port then dumping the data and then writing some visual basic code to sort it out. Is this possible?
I understand there may need to be timing considerations, matching the ccd clock speed and vb code to read at correct times and work together.
This is all very new to me and not sure where to go any help or advice is greatly appreciated.
Need to have some sort or basic summary outline by friday, reasonably low budget and will run for maybe 3 months.
Thanks in advance.
  #2
Old 10-02-2012, 06:49 PM
crutschow's Avatar
crutschow crutschow is online now
Senior Member
Default
The datasheet for that device tells nothing about how to connect or use it. Unless you can find more info on how it works, I don't see how you can use it. It's far too complex a device to guess at how to connect to it.
__________________
Zapper
Curmudgeon Elektroniker
  #3
Old 10-03-2012, 08:28 PM
New Member
Default Thanks
This is what I feared, I have contacted Toshiba and other organisations for further information, can anyone perhaps advise on the other aspects on my project?
  #4
Old 10-03-2012, 10:01 PM
crutschow's Avatar
Senior Member
Default
What's the problem with the USB CCD?
__________________
Zapper
  #5
Old 10-04-2012, 10:35 PM
New Member
Default Nothing
Nothing wrong with it, it is probably what I will use as I cannot see the sensor going anywhere soon..
If I use the USB CCD which direction should I go in?
  #6
Old 10-04-2012, 11:14 PM
crutschow's Avatar
Senior Member
Default
Up -- down -- sideways?
Can't help unless I know what the part number is of the device.
__________________
Zapper
  #7
Old 10-04-2012, 11:51 PM
New Member
Thumbs up Apologies
Very sorry, will post this shortly.
Tags
Similar Threads
Thread Thread Starter Forum Replies Last Post
Uniformaly spaced linear array problem cigarsnob Radio and Communications 2 06-05-2011 05:16 PM
Linear CCD Slit Scan Camera ? Mustafa Umut Sarac The Projects Forum 7 06-22-2010 07:38 PM
Linear CCD Array CVMichael General Electronics Chat 24 01-26-2010 03:48 PM
CCD Array kax01 General Electronics Chat 8 04-08-2009 06:48 PM
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
