Emitter-follower analysis
gerases
Joined Oct 29, 2012
186
Hi all,
This circuit is driving me crazy and I'm not smart enough to figure it out on my own.
My question is: how do we get 6.42V on the base? Usually, there's a voltage divider at the base and then it's a little more simple. But here, I don't know where to start.
The whole emitter follower arrangement has a few mysteries for me. When the emitter goes straight to ground, it's clear, the base current flows, the CE path starts to pass current depending on how much current flows into the base, which in turn is determined by the base resistor.
With the emitter-follower, it's more complicated because the base current depends on Vload and the Vload depends on VCE, which in turn depends on Ib. It's like a chicken and egg problem.
Thank you!
gerases
Joined Oct 29, 2012
186
In this circuit you post the BJT is in a saturation. So I don't know what you want to do with this circuit?
Well, can you tell me how to calculate the drop over the Rin in general in a configuration like this?
Jony130
Joined Feb 17, 2009
5,488
Emitter follower is a very simply circuit. The output voltage is always 0.6V (Vbe) lower the the input voltage.
See some examples
Also notice that the base current is (β+1) smaller then emitter current (load current).
So our base current source B1 see our load ( Re resistor) not as 100Ω resistor. But B1 see (β+1)*Re load.
Here you have anther example.
Spouse we have a 1K resistor voltage divider supply from 10V battery.
Without any load connect to the output terminal of our voltage divider the output voltage is equal 5V. Now we connect a 100Ω load resistor across the output terminal.
And now our voltage divider output voltage drops from 5V to 0.83V. So we ruin our circuit.
To fix this issue we add a buffer (emitter follower) see the diagram
Now I hope that you see why we say that emitter follower has a high input impedance and low output impedance. It's all thanks to BJT and his current gain.
gerases
Joined Oct 29, 2012
186
Rin ?? I don't see any Rin resistor in the diagram.
By Rin I meant the 1K resistor on the base. Sorry.
Also have you try using this method? To solve this circuit?
http://forum.allaboutcircuits.com/sh...781#post585781
I tried to apply that method, but there, we have a voltage divider and everything is a bit simpler because we know the base voltage straight away. Here, I don't see where to begin. How come the base voltage in this case is not simply 9V?
Jony130
Joined Feb 17, 2009
5,488
As usually we start our analysis by applying Kirchhoff's law.
Vcc = IB*Rb + Vbe + Ie*Re
And for the BJT
Ie = Ib *(β + 1)
Ib = (Vcc - Vbe)/( Rb + Re*(β+1))
and Voltage at base
Vb = Vcc - Ib*Rb or Vb = Vbe + Ie*Re
So if we assume β = 100; and Vbe = 0.65V we have
Ib = (9V - 0.65)/(1K+ 1K*101) = 8.35V/102k = 81.87μA
and
Ie = 101 * 81.87μA = 8.26mA
Now we can check whether BJT is on active region or in saturation
Collector current cannot be greater than Ic_max = (Vcc - Vce_sat)/(Rc + Re) ≈ 9V/2K = 4.5mA.
But we calculate 8.26mA.
So if Ic >> Ic_max BJT is in saturation region. And in saturation Ic = β*IB don't hold anymore.
All we can do next is to write this equation
Ie = Ib + Ic
So we have
Ie = Ve/Re
Ib = (Vcc - Vbe - Ve)/Rb
Ic = (Vcc - Vce_sat - Ve)/Rc
And using these three equations we can solve for Ve
\(Ve = ( \frac{Vcc - Vbe}{RB} + \frac{Vcc - Vce_{sat}}{Rc}) * (RB||RC||RE) = 5.75V\)
So voltage at base is equal to
Vb = Vbe + Ve = 6.4V
I assume Vbe = 0.65V and Vce_sat = 0.1V.
This is all we need to do to find DC bias current in this circuit.
gerases
Joined Oct 29, 2012
186
Ie = Ib + Ic
So we have
Ie = Ve/Re
Very cool. What are the vertical bars in (RB||RC||RE)?
wmodavis
Joined Oct 23, 2010
739
Actually the circuit you refer to is not an emitter follower. It is a common emitter BJT circuit with the emitter resistor not bypassed.
Jony130
Joined Feb 17, 2009
5,488
How can you know that? There is no input/output terminal on the diagram.
And what if I connect "the load" directly to Re resistor?
34,469
Yes, if you take the output from Re it will be acting as an emitter follower. But a normal emitter follower circuit has no collector resistor since it serves no purpose and can actually slow down the stage response due to Miller negative AC feedback through the base-collector capacitance. So when a BJT stage is seen with both collector and emitter resistors, the logical assumption is that it is a CE circuit with an emitter bias stabilization resistor (which can be AC bypassed or not as required by the circuit requirements).
wmodavis
Joined Oct 23, 2010
739
I can know that because your original post was sooo incomplete wrt providing detail as to what you were asking. See Cruts post.
