Hi
I need some suggestions on how to measure distance between two points that don't have clear visibility to each other. The distance does change all the time, can be up to tens of meters, the measurement doesn't have to be very precise (around a meter resolution is good enough), and each end can have a transmitter/receiver or whatever it takes attached to it.
Here's why - we often go cycling with wife and kids. I usually lead the group, kids in the middle and wife in the end. I would like to know, without having to turn my head all the time, how far behind they are - sometimes a kid drops off, wife stops to help him and I only find out minutes later and have to come back with the other kiddies, etc. So my plan is to attach a small gadget on each bike, periodically measure the distance, display the readings and raise an alarm on my bike if they're too far.
However first I need to measure the distance. Any ideas? I was thinking of GPS modules but that sounds like an overkill. I'm sure there must be a simpler solution.
Thanks for any ideas!
