All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > The Projects Forum
Notices
The Projects Forum Working on an electronics project and would like some suggestions, help or critiques? If you would like to comment or assist others with their projects, this is the place to do it.
Reply   Post New Thread
Thread Tools Display Modes
  #11
Old 05-11-2012, 02:30 AM
suzuki suzuki is offline
Senior Member
Default
Quote:
Originally Posted by t_n_k View Post
If you are actually looking at the frequency response of the bridge rectifier plus RC load then that is a more uncertain problem.
Keep in mind that the diodes operate in discontinuous mode with the presence of a load filter capacitor.
A simplistic view is to consider the main AC supply cycle period to be infinitely long in comparison with the sweep frequency cycle period range. One would then consider one opposing diode pair of the diode bridge to be in quasi-static forward bias. In that case one would have the equivalent dynamic diode resistances in series with the load and the sweep frequency source. So one might expect to see a typical single pole -20dB per decade roll off.
It eludes me as to why one would want to know this ....???
I actually really like this idea. So in each half cycle, you essentially just have 2 diode resistances, the load R and C. I think this should give a pretty good idea of the frequency response.
I guess to clarify, i had the dc source there as a test for the frequency response. It should be ac going into the rectifier, and the capacitor is mainly for filtering.
  #12
Old 05-11-2012, 03:04 AM
Ron H's Avatar
Ron H Ron H is offline
E-book Developer
Default
Just remember this equation particularly applies to simulators:
Garbage In = Garbage Out
  #13
Old 05-11-2012, 05:23 AM
t_n_k t_n_k is offline
Senior Member
Default
I tried using PSIM for this 'concept' but obtained a better result using Simetrix.
The attachment shows the simulation model and two frequency response results for two different bridge AC input voltages - namely 2V p-p and 5V p-p. The result of differing diode dynamic resistances is readily observed with the lower cut-off frequency resulting from a lower AC source voltage.The dB ratio is obtained from the load capacitor back to the AC small signal source sensor / isolator.
The Following User Says Thank You to t_n_k For This Useful Post:
suzuki (09-12-2012)
  #14
Old 09-12-2012, 06:53 AM
Senior Member
Default
Thought I would bump this thread and continue rather than start a new one.
That is a pretty interesting result, t_n_k. Sorry, I did not see it until now as I've been away. The fact that the response changes so much based on the input voltage seems to make it even more difficult to model or at least approximate the bridge rectifier as a single frequency response transfer function.
Since this time, what I have tried to do is the following, although I'm not sure if it is correct, so I'd love to have some input regarding my method.
If we take that circuit you provided, I called the input port and then output of the diode bridge (before R1 and C1) , and lastly the port across C1 is
As you suggested in a previous post, consider the path through the diode bridge as a series resistor . Therefore, the total output voltage is given by where .
Would this voltage divider then give the correct transfer function? If you solve for , you get a single pole, but it doesn't appear that I would get the same DC gain values as you did in your SIMetrix model.
Thanks for your help.
Tags
Related Site Pages
Section Title
Worksheet Basic AC-DC power supplies
Worksheet Rectifier circuits
Textbook Rectifier circuits : Diodes And Rectifiers
Similar Threads
Thread Thread Starter Forum Replies Last Post
Testing an Industrial AC and DC Variable Speed Drives NiCeBoY General Electronics Chat 13 12-08-2013 02:11 PM
PSpice AC Frequency Sweep of Transfer Function jegues Homework Help 0 01-20-2011 10:08 PM
Common Source AC Sweep newbie217 General Electronics Chat 7 11-28-2010 01:03 AM
Performing ac sweep (small-signal analysis) for a resonant converter in MATLAB kautilya Programmer's Corner 0 09-08-2010 07:31 PM
AC sweep for transformer in LTSPICE dileepchacko General Electronics Chat 1 01-31-2009 01:41 AM
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
