All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > General Electronics Chat
Notices
General Electronics Chat Discussion forum for general chat about anything electronics related, including asking questions about material in the All About Circuits E-book, Worksheets, and Videos.
Reply   Post New Thread
Thread Tools Display Modes
  #11
Old 05-04-2012, 09:35 PM
shortbus's Avatar
shortbus shortbus is offline
Senior Member
Default
I thought your lathe motor was 440 - 220 3PH? Why not skip the transformer and connect for 220 3PH ?
  #12
Old 05-05-2012, 12:48 AM
catman81056 catman81056 is offline
Junior Member
Default
If I supply the 440 3ph I don't have to change anything, nothing else to convert on the machine. I picked up a 20 hp 3ph idler for a RPC. I'll just rig a pony motor to start the 20hp so the inital current draw will be lower.
  #13
Old 05-05-2012, 02:40 AM
gerty gerty is online now
Senior Member
Default
I'd really like to see a schematic of what you have in mind.
  #14
Old 05-05-2012, 03:09 PM
shortbus's Avatar
Senior Member
Default
Quote:
The change is just a few wires in the "pecker head", versus the cost of the transformer and the power loses in it.
  #15
Old 05-05-2012, 04:17 PM
Senior Member
Default
[QUOTE]I thought your lathe motor was 440 - 220 3PH?[/QUOTE
Which post was that in?
  #16
Old 05-05-2012, 10:15 PM
shortbus's Avatar
Senior Member
Default
[QUOTE=gerty;483894]
http://forum.allaboutcircuits.com/sh...ad.php?t=68528
The Following User Says Thank You to shortbus For This Useful Post:
gerty (05-06-2012)
  #17
Old 05-05-2012, 11:08 PM
takao21203's Avatar
takao21203 takao21203 is offline
Senior Member
Send a message via Skype™ to takao21203
Default
OP - The lathe is powered by a 440v 3ph, 5hp motor that pulls 8.8amps
So he wants to power this motor from 200 volts (using 15kW transformer, 200 --> 440 volts)? Is this correct?
(440/200) * 8.8 = 20 Amps input (w/o losses).
Also it's not clear how much the transformer will draw w/o load (since it is used in reverse).
  #18
Old 05-05-2012, 11:20 PM
crutschow's Avatar
crutschow crutschow is offline
Senior Member
Default
Quote:
A normal power transformer draws only a small magnetizing current, either forward or reverse, as long as its voltage ratings are not exceeded.
__________________
Zapper
Curmudgeon Elektroniker
  #19
Old 05-06-2012, 12:43 AM
Junior Member
Default
I think it's alittle more than switching a few wires, I have all the stuff needed, 3ph 20hp idler, 3 hp 220 1ph pony motor(I'll use this to bring the idler up to speed before applying power), the 6ga wire, and the 60 amp breaker box. All thats left to do is run the wire and fab up the frame work to mount the idler and pony motors. Thats some thing I enjoy doing. Here's what the electric panel looks like. It's alittle over my head.
  #20
Old 05-06-2012, 07:50 AM
takao21203's Avatar
Senior Member
Default
Well here we can see the control box.
More information is required or advice can only be guesswork:
-Type of motor, 3-phase, or eventually additional starter coil?
-Any capacitors used?
-How many phases on the grid? Single phase 200 volts? 3 phases?
-Any switches or buttons on the control box?
-Are the relays used to change between star/delta configuration?
-Or are they used to switch an external motor/generator? Is this done manually eventually for startup?
-Have you connected the transformer already?
Here a page I found containing information about "idler motor" circuits (to convert single phase to tri-phase).
http://www.metalwebnews.com/howto/ph-conv/ph-conv.html
Tags
Similar Threads
Thread Thread Starter Forum Replies Last Post
How to determine heater size... catman81056 General Electronics Chat 16 04-10-2012 02:50 PM
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
