All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > Homework Help
Notices
Homework Help Stuck on a textbook question or coursework? Cramming for a test and need help understanding something? Post your questions and attempts here and let others help.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 04-29-2012, 06:36 AM
theertham theertham is offline
Junior Member
Default transistor as an invertor circuit
can any body tell me the working of transistor as an invertor circuit.figure is attached
  #2
Old 04-29-2012, 06:49 AM
blah2222 blah2222 is offline
Senior Member
Default
Quote:
Well for AC-small-signal operation (DC = 0) you can use this model of the BJT to figure out what's going to happen:
In your case, you have the input connected to the base via R9 (10k), emitter tied to ground, and R10 (10k) in parallel with the output resistance (rout) of the BJT.
You need to find Vout as a function of Vin by first finding Vbe as a function of Vin and then Vout as a function of Vbe:
Knowing this, you can find out the amount of small-signal current running through the current source. Since the emitter is grounded, the current through this source will run through the parallel contribution of rout and R10 from ground to Vout. With this in mind, we can setup the following KCL equation:
Rearranging and subbing in for Vbe:
Where:
The negative sign shows why this is an inverting amplifier. (Math approach)
The Following User Says Thank You to blah2222 For This Useful Post:
theertham (04-29-2012)
  #3
Old 04-29-2012, 07:22 AM
crutschow's Avatar
crutschow crutschow is offline
Senior Member
Default
Its fairly simple.
Start out with zero volts on the input. This means the transistor is off and the collector output is at the supply voltage since there is no current through the collector resistor, R10.
Now start increasing the input voltage. That will cause base current to flow through R9 and the transistor will start to turn on with current starting to flow through R10. The causes an IR voltage drop across R10, reducing the collector voltage.
Thus as the input voltage is increasing, the output voltage is being reduced, thus the circuit acts as an inverter.
__________________
Zapper
Curmudgeon Elektroniker
The Following User Says Thank You to crutschow For This Useful Post:
  #4
Old 04-30-2012, 01:24 PM
Junior Member
Default transistor as inverting circuit
hi
i have attached the output from transistor inverter circuit which has 10k at the collector and 1 k at the base with emitter grounded.the output shows there is a slight curve at the top of the pulse.but when i connected 10k at the base and 1k at the collector with emitter ground,the output became perfect pulse.what could be the reason?
  #5
Old 05-01-2012, 07:38 AM
Junior Member
Exclamation transistor inverter circuit
[QUOTE=theertham;482160]hi
i have attached the output from transistor inverter circuit which has 10k at the collector and 1 k at the base with emitter grounded.the output shows there is a slight curve at the top of the pulse.but when i connected 10k at the base and 1k at the collector with emitter ground,the output became perfect pulse.what could be the reason?[/important]
  #6
Old 05-01-2012, 07:49 AM
Jony130 Jony130 is offline
Senior Member
Default
The effect you describe is caused by the parasitic capacity.
This capacitor is connect between collector and the gnd.
Tags
Related Site Pages
Section Title
Worksheet Class A BJT amplifiers
Video Lecture Amplifier Configurations - Transistors and Transistor Circuits
Video Lecture Transistor Biasing - Transistors and Transistor Circuits
Textbook Current mirrors : Bipolar Junction Transistors
Textbook Feedback : Bipolar Junction Transistors
Textbook The common-base amplifier : Bipolar Junction Transistors
Textbook The common-collector amplifier : Bipolar Junction Transistors
Textbook The common-emitter amplifier : Bipolar Junction Transistors
Textbook Bipolar junction transistors : Solid-state Device Theory
Textbook The "buffer" gate : Logic Gates
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
