| Homework Help Stuck on a textbook question or coursework? Cramming for a test and need help understanding something? Post your questions and attempts here and let others help. |
Thread Tools | Display Modes |
#1
can any body tell me the working of transistor as an invertor circuit.figure is attached
#2
Quote:
![]() In your case, you have the input connected to the base via R9 (10k), emitter tied to ground, and R10 (10k) in parallel with the output resistance (rout) of the BJT. You need to find Vout as a function of Vin by first finding Vbe as a function of Vin and then Vout as a function of Vbe: Knowing this, you can find out the amount of small-signal current running through the current source. Since the emitter is grounded, the current through this source will run through the parallel contribution of rout and R10 from ground to Vout. With this in mind, we can setup the following KCL equation: Rearranging and subbing in for Vbe: Where: The negative sign shows why this is an inverting amplifier. (Math approach) Last edited by blah2222; 04-29-2012 at 07:33 AM. |
| The Following User Says Thank You to blah2222 For This Useful Post: | ||
theertham (04-29-2012) | ||
#3
Its fairly simple.
Start out with zero volts on the input. This means the transistor is off and the collector output is at the supply voltage since there is no current through the collector resistor, R10. Now start increasing the input voltage. That will cause base current to flow through R9 and the transistor will start to turn on with current starting to flow through R10. The causes an IR voltage drop across R10, reducing the collector voltage. Thus as the input voltage is increasing, the output voltage is being reduced, thus the circuit acts as an inverter.
__________________
Zapper Curmudgeon Elektroniker |
| The Following User Says Thank You to crutschow For This Useful Post: | ||
#4
hi
i have attached the output from transistor inverter circuit which has 10k at the collector and 1 k at the base with emitter grounded.the output shows there is a slight curve at the top of the pulse.but when i connected 10k at the base and 1k at the collector with emitter ground,the output became perfect pulse.what could be the reason? |
#5
[QUOTE=theertham;482160]hi
i have attached the output from transistor inverter circuit which has 10k at the collector and 1 k at the base with emitter grounded.the output shows there is a slight curve at the top of the pulse.but when i connected 10k at the base and 1k at the collector with emitter ground,the output became perfect pulse.what could be the reason?[/important] |
#6
The effect you describe is caused by the parasitic capacity.
This capacitor is connect between collector and the gnd. |
| Tags |
| circuit, invertor, transistor |
Related Site Pages
| Section | Title | |||
| Worksheet | Class A BJT amplifiers | |||
| Video Lecture | Amplifier Configurations - Transistors and Transistor Circuits | |||
| Video Lecture | Transistor Biasing - Transistors and Transistor Circuits | |||
| Textbook | Current mirrors : Bipolar Junction Transistors | |||
| Textbook | Feedback : Bipolar Junction Transistors | |||
| Textbook | The common-base amplifier : Bipolar Junction Transistors | |||
| Textbook | The common-collector amplifier : Bipolar Junction Transistors | |||
| Textbook | The common-emitter amplifier : Bipolar Junction Transistors | |||
| Textbook | Bipolar junction transistors : Solid-state Device Theory | |||
| Textbook | The "buffer" gate : Logic Gates | |||
| Thread Tools | |
| Display Modes | |
