All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > General Electronics Chat
Notices
General Electronics Chat Discussion forum for general chat about anything electronics related, including asking questions about material in the All About Circuits E-book, Worksheets, and Videos.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 04-13-2012, 08:03 PM
EngIntoHW EngIntoHW is offline
Senior Member
Thumbs down Your opinion on RF switch
Thanks to Steve's help (ssnyde), I found an RF switch which seems suite to my cellular application.
I'll connect 2 cellular mobile phones (DUT + Reference) to the RF output ports, and an external antenna (located at the roof) to the input port.
The RF switch I found is CCR-33S3O - SPDT, 12V FAILSAFE, DC-18GHZ (http://www.alliedelec.com/search/pro...0578#tab=specs)
(133$ per unit)
This is its spec:
I actually need only DC - 3GHz (not DC - 18GHz), but haven't found one with that range.
I'd like to ask a few questions please:
1.
They don't mention in datasheet that DC should be blocked at the input/output ports, but the schematic doesn't include any DC block capacitors.
Does it make sense that the RF connector can absorb DC voltage that might be transmitted from the cellular mobiles or come from the antenna?
2.
Does the 60dB Isolation refer to Isolation between the 2 output ports or to the Isolation between the not-connected input port and the output port?
3.
Does the below graph mean that in the DC - 3GHz range, the switch can handle up to ~80W at each input/output port?
Thank you very much!
Tags
Related Site Pages
Section Title
Worksheet Phase-locked loops
Worksheet Signal modulation
Worksheet JFET amplifiers
Worksheet BJT amplifier troubleshooting
Worksheet Fundamentals of radio communication
Textbook Radio circuits -- INCOMPLETE : Practical Analog Semiconductor Circuits
Textbook Oscillator circuits -- INCOMPLETE : Practical Analog Semiconductor Circuits
Textbook Input and output coupling : Bipolar Junction Transistors
Textbook Vacuum tube audio amplifier : Discrete Semiconductor Circuits
Textbook Diode switching circuits : Diodes And Rectifiers
Similar Threads
Thread Thread Starter Forum Replies Last Post
Use Latching Switch to Generate Momentary Pulse GroundZero The Projects Forum 1 08-01-2011 10:25 PM
Special ARM Switch soulsurfing The Projects Forum 3 07-12-2011 08:46 AM
RF switch raa Radio and Communications 1 04-23-2011 05:48 AM
RF switch relay... WASkydiver The Projects Forum 0 04-07-2009 08:40 PM
Chef needs momentary switch help.auto related chefandy1969 The Projects Forum 5 04-01-2007 01:50 AM
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
