All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > General Electronics Chat
Notices
General Electronics Chat Discussion forum for general chat about anything electronics related, including asking questions about material in the All About Circuits E-book, Worksheets, and Videos.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 02-28-2012, 03:24 PM
airmail airmail is offline
New Member
Default Basic (analog) power point tracker without internal energy storage
For a project, I'm in search for a simple (and if possible: analog) maximum power point tracker circuit for a max 12V/2A solar panel without significant internal energy storage (like in big capacitors).
Purpose is to run a small DC motor efficiently (at max power point) directly from the solar panel without the use of a battery.
Thank you!!!
Last edited by airmail; 02-28-2012 at 03:35 PM. Reason: tried to make it more clear :p
  #2
Old 02-29-2012, 06:38 PM
New Member
Default
Yeah, I know most mppt's work with big capacitors but hey, isn't there really one technique out there to do it without one?
  #3
Old 03-01-2012, 03:28 PM
Bernard's Avatar
Bernard Bernard is offline
Senior Member
Default
Some ideas: www.edn.com/designideas Dec 5 2008. Solar-array controller needs no multiplier to maximise power.
Another speculation is what I call " Poor mans controller" which uses a small secondary solar panel to provide an open ckt V ref. From several plots of solar panel power output, it appears that peak power occurs at about 73% of OC V. If the main panel V is divided down with pot and fed to comparator + input, secondary panel V to - input. Output with power amplification drives motor with a signal looking like PWM, as logic response is much faster than motor response. This presumes that motor current is sufficient to pull collector V below 73% of OC V. or load motor, maybe a propeller?
  #4
Old 03-01-2012, 03:33 PM
Bernard's Avatar
Senior Member
Default
Surprise, another Pk Pwr.
  #5
Old 03-02-2012, 09:36 PM
New Member
Default
I think the EDN article is extremely interesting! Many thanks for that!
Tags
Related Site Pages
Section Title
Textbook Why L/R and not LR? : Rc And L/r Time Constants
Worksheet Open-loop opamp circuits
Worksheet Regulated power sources
Textbook Tesla polyphase induction motors : Ac Motors
Worksheet Step-up, step-down, and isolation transformers
Textbook Step-up and step-down transformers : Transformers
Textbook Special-purpose diodes : Diodes And Rectifiers
Textbook Voltmeter usage : Basic Concepts And Test Equipment
Textbook Electric fields and capacitance : Capacitors
Similar Threads
Thread Thread Starter Forum Replies Last Post
Total power in unbalanced wye jfrost General Electronics Chat 5 12-23-2010 12:02 AM
Power supply voltage for wireless access point davidc General Electronics Chat 4 10-25-2009 10:47 PM
Stanly Meiyer Explained with science. h2opower Off-Topic 57 09-10-2009 12:15 PM
HH0 generator project galveston Off-Topic 19 06-27-2009 11:40 AM
Maximum Power Point Tracker for Solar PV module wasay General Electronics Chat 1 06-24-2009 03:16 AM
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
