Poly Variable Condenser (Pinout Question)
johncena
Joined Aug 15, 2010
32
How do you connect the Poly Variable Condenser ( it has 3 pins) to the TDA7000 FM Receiver which only requires 2 pin for the Resonator part of the circuit.
i need that 2-60pF range of the PVC and i want to know what will i use between those 3 pins.
The technical spec is here --> http://mzentertainment.com/technical_archive/TTWM_variable_capacitor.gif
and here's the spec:
TTWM Poly Variable Condenser / Capacitor.
Two section, apx 60pF and 140pF max.
Commonly used in portable transistor AM/FM radios.
Here's the pic:
http://mzentertainment.com/store_pp_images/dzw_store_varicap_TTWM_60_160pf_000140_zoom.jpg
I would like to post the schematic, but unfortunately, the website was down at the moment.
But getting that 2-60pf in series with 56pf and parallel with 33pF and 56nH inductor will provide a 85Mhz to 113Mhz
Kermit2
Joined Feb 5, 2010
4,159
The center pin is common to both and without a clear indication on the datasheet, I would GUESS the Osc section would be the left side and the Ant section the right side when viewed from above with the pins toward you. If not then its the other way around :)
You just need to make connection with two pins. you can bend the other one up and allow the other two to go into the board. Be gentle. You may have to unbend it and bend the other side up if you get the wrong side.
johncena
Joined Aug 15, 2010
32
Thanks!, now i'm sure that Osc is in Leftside and Ant in the right side..
I just noticed it in the picture (the last part) there is a "O" and "A" lettering...
Thanks for the clarification on the pin parts.
