All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > The Projects Forum
Notices
The Projects Forum Working on an electronics project and would like some suggestions, help or critiques? If you would like to comment or assist others with their projects, this is the place to do it.
Closed Thread   Post New Thread
Thread Tools Display Modes
  #1
Old 04-14-2011, 05:54 AM
alyeomans alyeomans is offline
New Member
Default Wind Generator and Grid Tie Idea
Greeting All
I am investigating the idea of a Fisher and Paykel wind generator which needs a regulation and grid tie circuit. I have laid out a schematic below and would appreciate some experienced comments on this.
Please no comments of grid tie legality.
The 3 phase AC is converted to DC
The DC is chopped and put through a step up transformer. The chopper also regulates the voltage from the output to maintain a constant voltage?
The transformer output is rectified back to DC
The DC is then converted to mains synchronized AC and injected into the grid. This is not my idea I saw it on http://www.neo-aerodynamic.com/GridTieInverter.html
I would probably use FETs where possible.
run the PWM at a high freq to keep transformer smaller
I am assuming the a slightly higher voltage than mains potential will inject the current. Any ideas of what voltage?
Cheers
Al
  #2
Old 04-14-2011, 12:28 PM
beenthere's Avatar
beenthere beenthere is offline
Senior Member
Default
Have you read the initial statement on that site?
Quote:
Patent pending.
But your are free to copy and build on your own risk for individual usage and noncommercial purpose.
Not to be connected to the national grid without proper authorization.
As by products of our research we have come up with a logic to build grid tie inverters. They are very inexpensive and for the benefit of the PEOPLE AT LARGE we post here. We do not present as how to make but the process how we build them and for informative purpose only.
Super Warning: Dealing with live AC grid may cause bodily harm or death; therefore any attempt should be only done by well trained and professional.
Do you have any experience in electricity or electronics? Can you obtain that authorization to connect a homemade device to the power grid?
Closer reading of one paragraph shows this outfit does not stand behind this inverter in any way.
The thing looks like a good way to get killed.
__________________
First comes the hardware, then the software.
Last edited by beenthere; 04-14-2011 at 12:34 PM. Reason: Read statement more closely
  #3
Old 04-14-2011, 02:35 PM
wayneh wayneh is offline
Senior Member
Default
Quote:
Or arrested. The designer admits it's not approved, and I saw no evidence of testing. The chief attraction is that it's a cheap "solution". Maybe it's clever in that regard but it is NOT intended for doing a real grid tie-in.
I'd direct questions to the designer, but in the long run I think you'd be better off buying a real and approved solution.
  #4
Old 04-14-2011, 10:57 PM
New Member
Default
Thanks for your response guys.
beenthere: Yes I have read the site from top to bottom plus others too. yes I have experience and training in electrical and electronics. I would like to build and test this "eventually" after careful consideration and health and safety at the fore front of my mind - I was initially thinking of a low voltage (safe level) build for testing. The design does have merit which is why I am interested in it. I do not want to die and do have a suitable respect to AC mains.
weyneh: I appreciate that, the design is not approved which is okay too, but not why I posted this. I do not want to say 'much' on your comment about buying this - I am sure more than half the projects here could be purchased in some form but that is not the point.
Guys, I am looking at this as a project and I do know AC can kill and I know that I should not connect it too the grid. I would like some technical feedback on the circuit. You are both senior board members surely you have comments on its operation. Please lets look at this project and remember it's 'all about circuits'.
I have seen some posts saying to grid tie with constant current but my assumption is a higher voltage than mains is required to push the current. This means a constant voltage?
The triacs will operate with an on/off characteristic (squarish wave) which is not conducive to the desired sine wave output. I imagine a power fet would be better than a triac?
  #5
Old 04-15-2011, 12:09 AM
beenthere's Avatar
Senior Member
Default
Some reading through the subject brings up several points of view. This site has most of them in it - http://www.electronicspoint.com/re-s...s-t185044.html
As the non-approved equipment is a hazard in several ways, I do not think we can support further discussion. Approved tie inverters do cost more, but your insurance doesn't get canceled, nor do utility workers get electrocuted.
__________________
Tags
Related Site Pages
Section Title
Worksheet Thyristor application circuits
Worksheet Bipolar junction transistors in active mode
Worksheet Bipolar junction transistor theory
Worksheet Performance-based assessments for AC circuit competencies
Worksheet Advanced electromagnetism and electromagnetic induction
Textbook Combination tubes : Electron Tubes
Worksheet Peak, average, and RMS measurements
Textbook Special transformers and applications : Transformers
Textbook The TRIAC : Thyristors
Textbook Vacuum tube audio amplifier : Discrete Semiconductor Circuits
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
