All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > The Projects Forum
Notices
The Projects Forum Working on an electronics project and would like some suggestions, help or critiques? If you would like to comment or assist others with their projects, this is the place to do it.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 02-26-2010, 08:24 PM
yasirsajjad yasirsajjad is offline
New Member
Red face Passenger Lift Control Diagram
Hi
Can any body mail me Passenger Lift control diagram (electrical relay logic)
i will be highly thankful
Regards
Yasir Sajjad
<snip>
Last edited by bertus; 02-26-2010 at 08:57 PM. Reason: Removed email address to protect you from spambots
  #2
Old 02-26-2010, 11:52 PM
andreapg andreapg is offline
Junior Member
Default
In the following pdf link (last page) you can find a circuit schematic which works for a 4 floors elevator, with manual doors. I'll try to explain you how it works(can't speek english very well).
Between T1 and T4 (bold line) you can see the main safety switches:
over run switches (they turn off the equipment if a motor brake failure occurs);
floor door switch;
safety speed limit control (to prevent crashes);
stop button/car door safety switch.
In the second (schematic) page, on the left you will see the drivig buttons:
P1-P2-P3-P4 are floor buttons; C1-C2-C3-C4 are car buttons.
RO delay allows the floor buttons (NT on Otis panels).
S1-S2-S3-S4 are mechanical exchange switches which are located in the shaft, on each floor. They reverse the car run, and they are turned through a shape installed on the car (look for "invertitore" and "sagoma").
D= down power relay
S= up power relay
GV= high speed power relay
PV= low speed power relay
RV= select car speed
IF= stop proximity magnetic switch (it opens the circuit once the car is on the floor).
When the car comes near the reserved floor, the related switch (S1-S2-S3-S4) takes the middle position: S or D keeps the high level through its 12-8 switch, but RV turns off. Than we have the speed exchange.
http://electronline.it/doc/asc.pdf
That schematic was designed with educational intent, than it is on the public domain.
  #3
Old 04-14-2010, 09:29 PM
Junior Member
Default
Uploaded the same schematic as a file attachment
Tags
Similar Threads
Thread Thread Starter Forum Replies Last Post
Basic temperature control project ronnierohan007 Homework Help 5 11-27-2009 10:41 PM
Need Help Looking For A Non PLC Ladder Diagram For: Jure George Homework Help 1 11-19-2009 04:02 PM
Need help for a dawn/dusk LED circuit malaybiswas The Projects Forum 24 03-04-2009 04:19 PM
Need diagram speed control nguyenphuchp The Projects Forum 1 05-26-2008 04:56 PM
Universal remote control schematic diagram yong The Projects Forum 12 03-02-2008 03:23 AM
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
