Could you explain please?VE remains constant and relative to VB. VRe changes with IC
Jony130, do you remember (can you provide a link) to an earlier post about biasing where you provided the expression for the case where part of the emitter resistance is bypassed with a capacitor?You get max output voltage swing if you pick Ic equal
\(Ic_{opt}=\frac{Vcc-Vce(sat)}{2(Rc+Re)}\)
what gives Vce≈0.5*Vcc
Yes,Jony130, do you remember (can you provide a link) to an earlier post about biasing where you provided the expression for the case where part of the emitter resistance is bypassed with a capacitor?
Hi guys,
Thanks a lot, i got it now.
Is it correct to say that:
VOUT(min) = VEE + IC*RE + VCE(SAT)
VOUT(max) = VCC
So to get maximal output voltage swing, i'd want to set VOUT at half way between VOUT(min) and VOUT(max).
