All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > General Electronics Chat
Notices
General Electronics Chat Discussion forum for general chat about anything electronics related, including asking questions about material in the All About Circuits E-book, Worksheets, and Videos.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 03-10-2010, 04:11 PM
phase ghost phase ghost is offline
Junior Member
Default Multimeter question - 3.5mm jacks
I've never owned or used a multimeter before and was wondering if I need to buy an adapter of sorts to measure voltage coming from a 3.5mm (1/8") patch cable. The voltages are coming from my modular synthesizer.
Thanks and apologies for the novice question.
  #2
Old 03-10-2010, 06:34 PM
beenthere's Avatar
beenthere beenthere is offline
Super Moderator
Default
That meter will be handy for many things, but not to characterize the time varying voltage out of a synthesizer. The meter does not respond fast enough to track the signal.
To visualize your synthesizer output, an oscilloscope is the thing to use. Follow this thread - http://forum.allaboutcircuits.com/sh...ad.php?t=35175 - to get freeware that lets you use your sound card as an audio oscilloscope (your monitor is the display).
__________________
First comes the hardware, then the software.
  #3
Old 03-10-2010, 06:56 PM
HoldenC HoldenC is offline
New Member
Default I think I tried that already.
I tried mesuring voltage coming from a headphone TRS connector once, the volmeter doesn't pick any stable voltage from there, it varies a lot, and not "a lot" like going up or down, it's actually a frecuency. It has to do with digital-to-analog signal conversion. It's like trying to measure the frequency of sound with a voltmeter.
  #4
Old 03-10-2010, 11:06 PM
someonesdad someonesdad is offline
Senior Member
Default
Quote:
The answer is yes, you'll need an adapter. It would be straightforward to make one from a plug, some wire, and two 4 mm banana plugs. These can be found at a store like Radio Shack.
You don't say why you want to measure the signal. There are nuances involved, as beenthere alluded to. If the synthesizer is putting out a sine wave within the bandwidth of your multimeter, then you can meaningfully measure the output. If your multimeter is RMS responding, then it doesn't have to be a sine wave. But few multimeters have a 50-100 kHz bandwidth, which is about what you'd want to get accurate RMS readings up to around 20 kHz.
If you tell us what it is you're trying to do, you'll get better advice.
An oscilloscope is a much better tool to examine the output and even inexpensive scopes should be able to deal with the output, assuming it's in the audio range of frequencies.
  #5
Old 03-11-2010, 02:46 AM
Junior Member
Default
I should have been more specific. I'm going to build a sequencer for my modular synth. I would like to see what kind of voltages my current sequencer sends.
It's not a vco, so it's not generating audio frequencies. It sends control voltages that trigger vco's and gates that trigger envelopes. My goal is to find out the voltages being sent from the sequencer. In particular, I want to know what voltage the gates are being triggered at. I've read 3v, 5v and a range of voltages. I'd like to know for sure. An oscilloscope is out of my price range at the moment, but is on the wishlist. As far as I know, sequencers generate regular voltages.
  #6
Old 03-11-2010, 02:40 PM
Senior Member
Default
Unless you have some special knowledge about the circuit's output, the only tool appropriate for this is an oscilloscope. If you don't have one, maybe you can barter with someone to trade for some time on one. There's also the approach of using the sound card on a computer with some software to make a poor man's oscilloscope.
Bookmarks
Tags
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
phone jacks and cat5 ? Mathematics! Computing and Networks 13 02-07-2010 05:44 AM
Really simple multimeter question ke5nnt General Electronics Chat 4 11-11-2009 02:39 PM
Multimeter Problem hazim General Electronics Chat 18 08-05-2009 07:09 PM
Question about a reading on a multimeter MrZeus General Electronics Chat 8 05-15-2009 05:21 PM
Multimeter Question with generator pbalien73 The Projects Forum 16 01-09-2009 11:48 PM
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License. Powered by vBulletin® Version 3.8.5
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
